I’m switching out my Asus RT-N66U (running Asuswrt-Merlin) for an RB3011. I’ve found how to set most everything but am baffled by IPTV. In the LAN settings of the Asus there is an IPTV tab where I can set the ISP profile, the VLAN ID, the PRIO and enabling the multicast routing. Any help would be appreciated.
Try this: https://www.taisto.org/RouterOS_IPTV/en
I maked this manual for Sonera IPTV, working…
Thanks for the info, unfortunately the linked page asks me to “install multicast-6.24rc4-mipsbe.npk into the RouterOS operating system RouterOS#P.C3.A4ivitt.C3.A4minen following these instructions” which is a Finnish page that doesn’t translate. Does that second page just tell me now to install the npk?
router os 6 not supported iptv
even if you set up according to the instructions, the router creates an excessive load on the network, channel and a processor, as a result of the connection is lost, hope to version 7 this defect, there is the same if you put the IPTV set-top box to the router
http://www.technotrade.com.ua/Articles/iptv_config_mikrotik.php
Hap AC excellent work with IPTV and not freeze internet even Wi-Fi
Routing power does not come for free. Get a more powerful one and it will work. Just don’t expect miracles from a sub-$50 device. And probably v7 will not solve anything for the same hardware.
Sales there are many routers to $ 30, which perfectly IPTV broadcast, so the price does not mean a great performance, I am able to spend $ 500, and if the device is fully fulfill my requirements, please visit the forum carefully, in version 7 will be a complete IPTV support
We have to see v7 first. For the moment it is a kind of unicorn, probably available in the next decade.
Until then, the only option to discipline IPTV on a MT is CPU based, so the low end models don’t cut it (I was referring to MT low cost routers only in the prev. post).
Oh, seems not translated… So just download package from http://www.mikrotik.com/download (Included in Extra packages). So download Extra package and extract that. You get multicast package, so drag and drop to winbox or use SSH. Put that to /root on Mikrotik and then reboot. Package will installed and now you see IGMP proxy under /routing
On my network IPTV working well with Mikrotik ARM and HAP AC wireless ok. IPTV need 5-10Mbps (10Mbps if HD).
