My ISP using coaxial cable, the cable, modem and tv box located in my workshop room.
Modem from ISP connected to my routerboard and i have 3 CAPs to cover all area in my room and this working normally.
Then i have issue with my TV Box, since TV Box also using coax cable and my TV located not in my workshop room but on Bedroom and on living room.
So anyone know here is routerboard have hardware how to broadcasting my TV Box so i can watch from my bedroom? Maybe Coax to IP converter, or anyone here have another suggestions?
Might be an option for you, Triax HDMI to COFDM DVB-T Modulator
Run a coaxial cable to your bedroom
Thanks for your suggestion. I prefer not to pull the coax from workshop room to bedroom.
Also on my workshop room i have pc will running 24 hours, maybe we can connect the TV box to this PC and build this PC as streaming server so another device can stream from this PC?
What kind of TV box is it?
This can be done very easy using linux receivers, like OCTAGON or Gigablue if you want to side step the TV subscription.
To setup the PC as a streaming server you with need tuner cards if your taking feeds from an aerial or satellite dish.
TBS5302 1080P USB3.0 HDMI Video Capture Card will capture live and restream into network, so this could be an option but you can only capture 1 channel
Might not be the answer you are looking for.
But IP over coax , coexisting with the TV distribution, is possible.
I use a set of “Hirschmann Inca 1G (Internet over coax)” on my TV distribution.
Quite expensive but better than POweline adaptors.
