or interfaces adopt addresses.
I have searched the forum and asked Google, but am unable to come up with any references to this.
This has happened on a number of devices, both RB450G and RB850Gx2, currently running 6.35.2. I use these as gateway/firewall/routers for home and small business networks. The most recent occurrence was this evening, when I found that traffic wasn’t routeing from a web server in the DMZ to a database server in the internal zone.
The correct addressing is as follows:
[admin@acheron] >> /ip address print detail
0 address=10.2.0.1/24 network=10.2.0.0 interface=ether2-internal-LAN
actual-interface=ether2-internal-LAN
1 address=10.2.1.1/24 network=10.2.1.0 interface=ether3-internal-wireless
actual-interface=ether3-internal-wireless
2 address=10.2.30.1/24 network=10.2.30.0 interface=vlan-wireless-guest
actual-interface=vlan-wireless-guest
3 address=172.16.0.1/24 network=172.16.0.0 interface=ether4-internal-DMZ
actual-interface=ether4-internal-DMZ
4 address=192.168.1.2/24 network=192.168.1.0 interface=ether1-external-gateway
actual-interface=ether1-external-gateway
What happened this time was that the 172.16.0.0 subnet appeared on ether2-internal-LAN as well as the 10.2.0.0 subnet..
Please note that I looked at and fixed this in Winbox, so have no record of the value of actual-interface when the fault appeared.
Has anyone ever observed something like this and, if so, can you point me at any possible solutions?
Regards
Graeme
