I’m trying to configure ipv6 and I’m having some issues.
I’m pretty new to ipv6
My Isp provides me with a /56 ipv6 subnet. He does not provide anything else, no SLAAC, no dhcp v6, just static range assigned and terminated to my network port.
I’d like to split that into multiple /64 subnets
Internally on my ccr traffic between the multiple /64 works fine.
My router is able to ping and access the internet through ipv6.
My different lan clients are not able to access the internet through ivp6.
The different lan clients are however able to reach different subnets created as well as the different gateways (lans / wan) defined.
How do I route traffic from a /56 to a /64 and vice versa.
I’ve tried everything usefull that I’ve already found on this forum but to no avail.
The closest post I’ve found with similar issues is the following but without a solution to the problem
http://forum.mikrotik.com/t/routerboard-hardware-interference-with-midband-2-way-radios/64/1
at this point I’ve set up an ip adress on the wan and ip addresses on different lans.
the range assigned xxxx:xxxx:6:400::1/56
Ip address
/ipv6 address print
# ADDRESS FROM-POOL INTERFACE ADVERTISE
0 G xxxx:xxxx:6:410:e68d:8cff:fe3d:38e5/64 LAN4 yes
1 G xxxx:xxxx:6:402:e68d:8cff:fe3d:38e9/64 LAN3 yes
2 G xxxx:xxxx:6:404:e68d:8cff:fe3d:38e9/64 LAN2 yes
3 G xxxx:xxxx:6:406:e68d:8cff:fe3d:38e9/64 LAN1 yes
4 G xxxx:xxxx:6:401::255/64 WAN no
routing table
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, o - ospf, b - bgp, U - unreachable
# DST-ADDRESS GATEWAY DISTANCE
0 A S ::/0 fe80::2d0:xxxx 0
1 X S ::/0 xxxx:xxxx:6:400::1 0
2 A SU xxxx:xxxx:6:400::/56 1
3 ADC xxxx:xxxx:6:401::/64 WAN 0
4 ADC xxxx:xxxx:6:402::/64 LAN3 0
5 ADC xxxx:xxxx:6:404::/64 LAN2 0
6 ADC xxxx:xxxx:6:406::/64 LAN1 0
7 ADC xxxx:xxxx:6:410::/64 LAN4 0
nd
Flags: X - disabled, I - invalid, * - default
0 * interface=all ra-interval=3m20s-10m ra-delay=3s mtu=unspecified reachable-time=unspecified retransmit-interval=unspecified ra-lifetime=30m
hop-limit=unspecified advertise-mac-address=yes advertise-dns=no managed-address-configuration=no other-configuration=no
I’ve tried setting default router ::/0 to the xxxx:xxxx:6:400::1 or the the link local address. (the ccr can reach the internet on either gateway adress…)
I’ve also tried defining or not defining xxxx:xxxx:6:400::/56 as unreachable.
Neither of these options makes a difference.
At this point there are no firewall rules that are blocking anything.
I’ve tried playing with Neighbor Discovery but that doesn’t change anything either.
So how can I translate the /56 to a /64 range and back so that my routing works ?
thanks
