Ipv6 address distribution
Hello Everyone,
Having issue distribute ipv6 address from tunnel broker assigned subnet.
My setup
|----- Desktop 1
Tunnel broker ------ Internet ---- Mikrotik Main Router ----- Mikrotik Access Point 1 |------ Desktop 2
|------ Deskop 3
------ Mikrotik Access Point 2
I setup tunnel to broker and assigned IP address from assigned tunnel subnet —> Works ( be able ping ip of ipv6 google though the tunnel from “Mikrotik Access Point 1”)
I added on “Mikrotik Main Router” dhcp server with assigned routed subnet to pool and set advertise it though interface where attached “Mikrotik Access Point 1”
[volga629@canlrt01] > /ipv6 dhcp-server print detail
Flags: D - dynamic, X - disabled, I - invalid
 0    name="dhcp-ipv6" interface=vlan220-ap1 address-pool=pool-ipv6 lease-time=3d rapid-commit=yes preference=255 duid="0x000300014c5e0cb3c2a0"
[volga629@canlrt01] > /ipv6 pool print
Flags: D - dynamic
 #   NAME        PREFIX                                      PREFIX-LENGTH EXPIRES-AFTER
 0   pool-ipv6        2001:xxx:xx:xxx::/64                                   72
[volga629@canlrt01] > /ipv6 in
dhcp-client  settings
[volga629@canlrt01] > /ipv6 address print
Flags: X - disabled, I - invalid, D - dynamic, G - global, L - link-local
 #    ADDRESS                                     FROM-POOL INTERFACE        ADVERTISE
11  G 2001:xxx:xx:xxx:xxx::1/64                   pool-ipv6 vlan220-ap1        yes
Then I enabled dhcp-client on “Mikrotik Access Point 1” and bound prefix from “Mikrotik Main Router” . After that I advertised on wifi bridge pool from bound subnet and this part doesn’t work. All desktops is Linux. Ipv6 addresses is not assigned not actual desktops. Mikrotik run last software level 6.36.
[volga629@can01nlap03] > /ipv6 dhcp-client print
 #    INTERFACE              STATUS        REQUEST              PREFIX                                                           ADDRESS
 0    ether1-gateway         bound         prefix               2001:xxx:xx:xxx:xxx::/72, 2d22h55m7s
[volga629@can01nlap03] > /ipv6 address print
 0  G 2001:xxx:xx:xxx:xxx::/64                        pool      bridge-wifi        yes
 1 DL fe80::4e5e:cff:fec4:5559/64                           bridge-wifi        no
 2 DL fe80::4e5e:cff:fec4:5559/64                           ether1-gateway        no
Any help thank you.
Could you post the output from
/ipv6 nd export
This output on “Mikrotik Access Point 1”
[volga629@can01nlap03] > /ipv6 nd export
# aug/07/2016 15:47:24 by RouterOS 6.36
# software id = NN8I-H0IA
/ipv6 nd
set [ find default=yes ] interface=bridge-wifi other-configuration=yes
/ipv6 nd prefix default
set autonomous=no
