No Error!
15:49:19 pptp,info TCP connection established from 19.19.16.207
15:49:19 pptp,info PPP: TCP connection established from 19.19.16.207
15:49:19 pptp,debug,packet PPP: rcvd Start-Control-Connection-Request from 19.19.16.207
15:49:19 pptp,debug,packet PPP: protocol-version=0x0100
15:49:19 pptp,debug,packet PPP: framing-capabilities=1
15:49:19 pptp,debug,packet PPP: bearer-capabilities=1
15:49:19 pptp,debug,packet PPP: maximum-channels=0
15:49:19 pptp,debug,packet PPP: firmware-revision=0
15:49:19 pptp,debug,packet PPP: host-name=
15:49:19 pptp,debug,packet PPP: vendor-name=Microsoft
15:49:19 pptp,debug,packet PPP: sent Start-Control-Connection-Reply to 19.19.16.207
15:49:19 pptp,debug,packet PPP: result-code=1
15:49:19 pptp,debug,packet PPP: error-code=0
15:49:19 pptp,debug,packet PPP: framing-capabilities=2
15:49:19 pptp,debug,packet PPP: bearer-capabilities=0
15:49:19 pptp,debug,packet PPP: firmware-revision=1
15:49:19 pptp,debug,packet PPP: host-name=MikroTik
15:49:19 pptp,debug,packet PPP: vendor-name=MikroTik
15:49:19 pptp,debug,packet PPP: rcvd Outgoing-Call-Request from 19.19.16.207
15:49:19 pptp,debug,packet PPP: call-id=39186
15:49:19 pptp,debug,packet PPP: call-serial-number=30
15:49:19 pptp,debug,packet PPP: minimum-bps=300
15:49:19 pptp,debug,packet PPP: maximum-bps=100000000
15:49:19 pptp,debug,packet PPP: bearer-type=3
15:49:19 pptp,debug,packet PPP: framing-type=3
15:49:19 pptp,debug,packet PPP: packet-recv-window-size=64
15:49:19 pptp,debug,packet PPP: packet-processing-delay=0
15:49:19 pptp,debug,packet PPP: phone-number-length=0
15:49:19 pptp,debug,packet PPP: phone-number=
15:49:19 pptp,debug,packet PPP: subaddress=
15:49:19 pptp,ppp,debug PPP: <48>: LCP lowerup
15:49:19 pptp,ppp,debug PPP: <48>: LCP open
15:49:19 pptp,debug,packet PPP: sent Outgoing-Call-Reply to 19.19.16.207
15:49:19 pptp,debug,packet PPP: call-id=48
15:49:19 pptp,debug,packet PPP: peers-call-id=39186
15:49:19 pptp,debug,packet PPP: cause-code=0
15:49:19 pptp,debug,packet PPP: connect-speed=100000
15:49:19 pptp,debug,packet PPP: packet-recv-window-size=100
15:49:19 pptp,debug,packet PPP: physical-channel-id=0
15:49:19 pptp,debug,packet PPP: rcvd Set-Link-Info from 19.19.16.207
15:49:19 pptp,debug,packet PPP: peers-call-id=48
15:49:19 pptp,debug,packet PPP: send-accm=0xffffffff
15:49:19 pptp,debug,packet PPP: receive-accm=0xffffffff
15:49:19 pptp,debug,packet PPP: sent Set-Link-Info to 19.19.16.207
15:49:19 pptp,ppp,debug,packet PPP: <48>: rcvd LCP ConfReq id=0x0
15:49:19 pptp,ppp,debug,packet PPP: <mru 1400>
15:49:19 pptp,ppp,debug,packet PPP: <magic 0x5afd0118>
15:49:19 pptp,ppp,debug,packet PPP: <pcomp>
15:49:19 pptp,ppp,debug,packet PPP: <accomp>
15:49:19 pptp,ppp,debug,packet PPP: <callback 0x06>
15:49:19 pptp,ppp,debug,packet PPP: <48>: sent LCP ConfReq id=0x1
15:49:19 pptp,ppp,debug,packet PPP: <mru 1280>
15:49:19 pptp,ppp,debug,packet PPP: <magic 0x68f3ca83>
15:49:19 pptp,ppp,debug,packet PPP: <auth mschap2>
15:49:19 pptp,ppp,debug,packet PPP: <mrru 1600>
15:49:19 pptp,ppp,debug,packet PPP: <48>: sent LCP ConfRej id=0x0
15:49:19 pptp,ppp,debug,packet PPP: <48>: rcvd LCP ConfRej id=0x1
15:49:19 pptp,ppp,debug,packet PPP: <48>: sent LCP ConfReq id=0x2
15:49:19 pptp,ppp,debug,packet PPP: <48>: rcvd LCP ConfReq id=0x1
15:49:19 pptp,ppp,debug,packet PPP: <48>: sent LCP ConfAck id=0x1
15:49:19 pptp,ppp,debug,packet PPP: <48>: rcvd LCP ConfAck id=0x2
15:49:19 pptp,ppp,debug PPP: <48>: LCP opened
15:49:19 pptp,ppp,debug,packet PPP: <48>: sent CHAP Challenge id=0x1
15:49:19 pptp,ppp,debug,packet PPP: <challenge len=16>
15:49:19 pptp,ppp,debug,packet PPP: <name MikroTik>
15:49:19 pptp,ppp,debug,packet PPP: <48>: rcvd LCP Ident id=0x2
15:49:19 pptp,ppp,debug,packet PPP: MSRASV5.20
15:49:19 pptp,ppp,debug,packet PPP: <48>: rcvd LCP Ident id=0x3
15:49:19 pptp,ppp,debug,packet PPP: MSRAS-0-BISHOP-\8F\8A
15:49:19 pptp,ppp,debug,packet PPP: <48>: rcvd LCP Ident id=0x4
15:49:19 pptp,ppp,debug,packet PPP: \C3\A8\F85\C6\82\E6I\AA\0B\E9hZ.\B4w
15:49:19 pptp,ppp,debug,packet PPP: <48>: rcvd CHAP Response id=0x1
15:49:19 pptp,ppp,debug,packet PPP: <response len=49>
15:49:19 pptp,ppp,debug,packet PPP: <name tester>
15:49:19 pptp,ppp,info,account tester logged in, 0.0.0.0
15:49:19 pptp,ppp,info,account PPP: tester logged in, 0.0.0.0
15:49:19 pptp,ppp,debug,packet PPP: <48>: sent CHAP Success id=0x1
15:49:19 pptp,ppp,debug,packet PPP: S=F3A3FFAF50D205E4B2618CA5E7234BF8C67DA9F1
15:49:19 pptp,ppp,debug,packet PPP: <48>: sent CBCP CallbackReq id=0x0
15:49:19 pptp,ppp,debug,packet PPP: 01 02
15:49:19 pptp,ppp,debug,packet PPP: <48>: rcvd CBCP CallbackResp id=0x0
15:49:19 pptp,ppp,debug,packet PPP: <48>: sent CBCP CallbackAck id=0x1
15:49:19 pptp,ppp,info <pptp-tester>: authenticated
15:49:19 pptp,ppp,info PPP: <pptp-tester>: authenticated
15:49:19 pptp,ppp,debug PPP: <48>: IPCP lowerup
15:49:19 pptp,ppp,debug PPP: <48>: IPCP open
15:49:19 pptp,ppp,debug,packet PPP: <48>: sent IPCP ConfReq id=0x1
15:49:19 pptp,ppp,debug,packet PPP: <addr 10.100.100.1>
15:49:19 pptp,ppp,debug PPP: <48>: IPV6CP lowerup
15:49:19 pptp,ppp,debug PPP: <48>: IPV6CP open
15:49:19 pptp,ppp,debug,packet PPP: <48>: sent IPV6CP ConfReq id=0x1
15:49:19 pptp,ppp,debug,packet PPP: <interface-identifier 0:0:f0:30>
15:49:19 pptp,ppp,debug PPP: <48>: MPLSCP lowerup
15:49:19 pptp,ppp,debug PPP: <48>: MPLSCP open
15:49:19 pptp,ppp,debug,packet PPP: <48>: sent MPLSCP ConfReq id=0x1
15:49:19 pptp,ppp,debug PPP: <48>: BCP open
15:49:19 pptp,ppp,debug PPP: <48>: CCP lowerup
15:49:19 pptp,ppp,debug PPP: <48>: CCP open
15:49:19 pptp,ppp,debug,packet PPP: <48>: sent CCP ConfReq id=0x1
15:49:19 pptp,ppp,debug,packet PPP: <mppe 1000040>
15:49:19 pptp,ppp,debug,packet PPP: <48>: rcvd IPV6CP ConfReq id=0x5
15:49:19 pptp,ppp,debug,packet PPP: <interface-identifier dc18:5864:d56c:64c7>
15:49:19 pptp,ppp,debug,packet PPP: <48>: sent IPV6CP ConfAck id=0x5
15:49:19 pptp,ppp,debug,packet PPP: <48>: rcvd CCP ConfReq id=0x6
15:49:19 pptp,ppp,debug,packet PPP: <48>: sent CCP ConfAck id=0x6
15:49:19 pptp,ppp,debug,packet PPP: <48>: rcvd LCP ProtRej id=0x7
15:49:19 pptp,ppp,debug,packet PPP: 80 21 01 01 00 0a 03 06 0a 64 64 01
15:49:19 pptp,ppp,debug PPP: <48>: IPCP lowerdown
15:49:19 pptp,ppp,debug,packet PPP: <48>: rcvd IPV6CP ConfAck id=0x1
15:49:19 pptp,ppp,debug PPP: <48>: IPV6CP opened
15:49:19 pptp,ppp,info <pptp-tester>: connected
15:49:19 pptp,ppp,info PPP: <pptp-tester>: connected
15:49:19 pptp,ppp,debug,packet PPP: <48>: rcvd LCP ProtRej id=0x8
15:49:19 pptp,ppp,debug,packet PPP: 82 81 01 01 00 04
15:49:19 pptp,ppp,debug,packet PPP: <48>: rcvd CCP ConfAck id=0x1
15:49:19 pptp,ppp,debug PPP: <48>: CCP opened
15:49:19 pptp,ppp,info <pptp-tester>: using encoding - MPPE128 stateless
15:49:19 pptp,ppp,info PPP: <pptp-tester>: using encoding - MPPE128 stateless
15:49:39 pptp,debug,packet PPP: rcvd Set-Link-Info from 19.19.16.207
15:49:39 pptp,debug,packet PPP: peers-call-id=48
15:49:39 pptp,debug,packet PPP: send-accm=0xffffffff
15:49:39 pptp,debug,packet PPP: receive-accm=0xffffffff
15:49:39 pptp,debug,packet PPP: sent Set-Link-Info to 19.19.16.207
15:49:39 pptp,debug,packet PPP: peers-call-id=39186
15:49:39 pptp,ppp,debug,packet PPP: <48>: rcvd LCP TermReq id=0x9
15:49:39 pptp,ppp,debug,packet PPP: Z\FD\01\18\00<\CDt\00\00\00\00
15:49:39 pptp,ppp,debug PPP: <48>: LCP closed
15:49:39 pptp,ppp,debug PPP: <48>: CCP lowerdown
15:49:39 pptp,ppp,debug PPP: <48>: CCP closed
15:49:39 pptp,ppp,debug PPP: <48>: BCP lowerdown
15:49:39 pptp,ppp,debug PPP: <48>: BCP down event in starting state
15:49:39 pptp,ppp,debug PPP: <48>: IPCP lowerdown
15:49:39 pptp,ppp,debug PPP: <48>: IPCP down event in starting state
15:49:39 pptp,ppp,debug PPP: <48>: IPV6CP lowerdown
15:49:39 pptp,ppp,debug PPP: <48>: IPV6CP closed
15:49:39 pptp,ppp,debug PPP: <48>: MPLSCP lowerdown
15:49:39 pptp,ppp,debug,packet PPP: <48>: sent LCP TermAck id=0x9
15:49:39 pptp,ppp,debug PPP: <48>: LCP lowerdown
15:49:39 pptp,ppp,info <pptp-tester>: terminating...
15:49:39 pptp,ppp,info PPP: <pptp-tester>: terminating...
15:49:39 pptp,ppp,debug PPP: <48>: LCP down event in starting state
15:49:39 pptp,ppp,info,account tester logged out, 20 5791 682 30 12
15:49:39 pptp,ppp,info,account PPP: tester logged out, 20 5791 682 30 12
15:49:39 pptp,ppp,info <pptp-tester>: disconnected
15:49:39 pptp,ppp,info PPP: <pptp-tester>: disconnected
