IPv6 basics
I try to configure a Router that is connected to the provider’s box.
New to IPv6, I have a working IPv4 config on another router A with routing, port forwarding and so on.
I’d like to use IPv6 on the internal network.
I have a prefix provided by the provider : 2a05:xxxx:xxxx:xxxx::/64.
But whatever I do, I have cannot see any IPv6 adress for the router except private ones :
eth1 = fe80::7a9a:18ff:fed7:f3d5/64
bridge = fe80::7a9a:18ff:fed7:f3d6/64
Guidelines to have it working would be welcome :slight_smile:
Would you post your IPv6 configuration?
/ipv6 export
