IPv6 BGP Peer
I am new in IPv6 , i am actually want to peer the ipv6 address(advt. my ipv6 address) with my internet provider, they already provide the peer ip address, i am confusing in peering the ipv6 address in mikrotik ,so i needed a little help with configuration , i have already peer ipv4 with my internet provider , its works fine but i need some advice in peering ipv6.
Regards,
Prasanta Shanglakpam
It works more or less the same way as IPv4 peering does.
You’ll just need to add the ISP’s IPv6 address as if it were a completely separate peer (which technically it is).
Then on the peer configuration, disable the IPv4 address family and enable the IPv6 address family. Make sure your in / out filters are set the way you need them to be, and you’re good to go.
