I have 2 x CCR’s both running full ip4 BGP to multiple upstreams all working fine.
I have started to set up dual stack ipv6 separate sessions to ipv4.
Ipv6 is up and announces my /32
I have a default route out which routes fine, I can ping ipv6 Google DNS and I can ping from USA to my ipv6 internally. All fine.
I would delete the default route once BGP is working but the BGP routes show as unreachable:
When I delete the default route nothing pings as you would expect that due to the BGP routes being unreachable
On one CCR the ipv6 IP connected to the upstream is on fibre port, on the other CCR I have tried it on a bridge. both do the same BGP unreachable on incomming routes.
0 A S dst-address=::/0 gateway=2001:978:2:21::59:1
gateway-status=2001:978:2:21::59:1 reachable via ipv6-cogent distance=1 scope=30
target-scope=10
1 Db dst-address=2001::/32 gateway=fe80::6600:f1ff:feef:5c0%ipv6-cogent
gateway-status=fe80::6600:f1ff:feef:5c0%ipv6-cogent unreachable distance=20 scope=40
target-scope=10 bgp-as-path="174,2914,12859" bgp-med=9031 bgp-origin=igp
bgp-communities=174:21100,174:22008 received-from=cogentIPv6
2 Db dst-address=2001:200::/32 gateway=fe80::6600:f1ff:feef:5c0%ipv6-cogent
target-scope=10 bgp-as-path="174,2914,2500" bgp-med=9031 bgp-atomic-aggregate=yes
bgp-origin=igp bgp-communities=174:21100,174:22008 received-from=cogentIPv6
3 Db dst-address=2001:200:c00::/40 gateway=fe80::6600:f1ff:feef:5c0%ipv6-cogent
target-scope=10 bgp-as-path="174,1239,4725,9607,7530,7530" bgp-med=81051
bgp-origin=igp bgp-communities=174:21000,174:22013 received-from=cogentIPv6
4 Db dst-address=2001:200:c000::/35 gateway=fe80::6600:f1ff:feef:5c0%ipv6-cogent
target-scope=10 bgp-as-path="174,1280,2500,23634" bgp-med=141061 bgp-origin=igp
bgp-communities=174:21001,174:22013 received-from=cogentIPv6
5 Db dst-address=2001:200:e000::/35 gateway=fe80::6600:f1ff:feef:5c0%ipv6-cogent
target-scope=10 bgp-as-path="174,1239,4725,2907,7660" bgp-med=81051 bgp-origin=igp
6 Db dst-address=2001:208::/32 gateway=fe80::6600:f1ff:feef:5c0%ipv6-cogent
Announcements fine
PEER PREFIX NEXTHOP AS-PATH ORIGIN LOCAL-PREF
cogen... 2a02:4f60::/32 2001:978:2:21... igp
Instance…
name="ipv6Cogent" as=60198 router-id=0.0.0.0 redistribute-connected=no
redistribute-static=no redistribute-rip=no redistribute-ospf=no
redistribute-other-bgp=no out-filter="" client-to-client-reflection=no
ignore-as-path-len=no routing-table=""
peer
E name="cogentIPv6" instance=ipv6Cogent remote-address=2001:978:2:21::59:1 remote-as=174
tcp-md5-key="REMOVED" nexthop-choice=default multihop=no route-reflect=no
hold-time=3m keepalive-time=10s ttl=60 in-filter=ipv6-cogent-in
out-filter=ipv6-cogent-out address-families=ipv6 update-source=2001:978:2:21::59:2
default-originate=never remove-private-as=no as-override=no passive=no use-bfd=no
filters …
5 chain=ipv6-cogent-in prefix=::/0 invert-match=no action=accept
set-in-nexthop-ipv6=2001:978:2:21::59:1 set-in-nexthop-direct=ipv6-cogent
set-bgp-prepend-path=""
7 chain=ipv6-cogent-out prefix=2a02:4f60::/32 prefix-length=32 invert-match=no action=accept
set-bgp-prepend-path="" set-bgp-communities=""
8 chain=ipv6-cogent-out invert-match=no action=discard set-bgp-prepend-path=""
bridge interface (now on other CCR no bridge IP direct on interface but same problem)
0 G address=2001:978:2:21::59:2/112 from-pool="" interface=ipv6-cogent
actual-interface=ipv6-cogent eui-64=no advertise=no
I have tried adding to inbound filter:
Also in aggregate do I need this on ipv6 BGP, I do on ipv4 but ipv6 is it relevant?
/routing bgp aggregate> print
Flags: X - disabled, A - active
# PREFIX INSTANCE
1 2a02:4f60::/32 ipv6Cogent
And is this relevant on ipv6 (network)
/routing bgp network> print
Flags: X - disabled
# NETWORK SYNCHRONIZE
1 2a02:4f60::/32 yes
Anyone know why my BGP routes IN are unreachable?
Tony
