Hi guys, I switched to Starlink a month ago and started using IPv6. I set up the default mikrotik IPv6 firewall and it works fine… except for IMAP servers under IPv6.
I telnet to my email provider’s IMAP and found the problem: Time out.
I tried disabling rules from the IPv6 FW, but not engouth. The bytes and packets count columns in the drop rules does not help me to understand the problem.
Any advice? Thank you!
ROS 7.15 @ hAP ax^2
Telnet output:
$ telnet imap.mailbox.org 993
Trying 2001:67c:2050:b100:1:143:0:199...
Connection failed: Connection timed out
Trying 185.97.174.199...
Connected to imap.mailbox.org.
Escape character is '^]'.
telnet> QUIT
Connection closed.
Firewall rules:
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
