I’m trying to get IPV6 working and I think I’m almost there. The only think that doesn’t work is that I can’t ping or access external hosts from internal network.
Pinging ipv6 addresses works in RouterOS but not in internal hosts
All internal hosts are able to get an IPV6 address, ping each other and ping the router
Here is my configuration so far ( ethernet1 is connected to my ISPs modem and ethernet2 is connected to my internal network ):
[admin@MikroTik] /ipv6> pool print
Flags: D - dynamic
# NAME PREFIX PREFIX-LENGTH EXPIRES-AFTER
0 D copel 2001:1284:f005:cc2f::/64 64 23h26m22s
[admin@MikroTik] /ipv6> address print
Flags: X - disabled, I - invalid, D - dynamic, G - global, L - link-local
# ADDRESS FROM-POOL INTERFACE ADVERTISE
0 G 2001:1284:f005:cc2f::/64 copel ether2-master-local yes
1 DL fe80::e68d:8cff:fedc:e25f/64 ether1-gateway no
2 DG 2001:1284:f005:cc2f::1/64 ether1-gateway no
3 DL fe80::e68d:8cff:fedc:e260/64 ether2-master-local no
[admin@MikroTik] /ipv6> dhcp-client print
Flags: D - dynamic, X - disabled, I - invalid
# INTERFACE STATUS REQUEST PREFIX
0 ether1... bound address 2001:1284:f005:cc2f::/64, 23h26m2s
prefix
Flags: D - dynamic
0 D copel 2001:1284:f005:cc2f::/64 64 23h25m55s
[admin@MikroTik] /ipv6> route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, o - ospf, b - bgp,
U - unreachable
# DST-ADDRESS GATEWAY DISTANCE
0 ADS ::/0 fe80::e297:96ff:fe6a:... 1
1 ADC 2001:1284:f005:cc2f::/64 ether2-master-local 0
ether1-gateway
2 DSU 2001:1284:f005:cc2f::/64 1
[admin@MikroTik] > ping 2800:3f0:4001:810::200e
SEQ HOST SIZE TTL TIME STATUS
0 2800:3f0:4001:810::200e 56 58 24ms echo reply
1 2800:3f0:4001:810::200e 56 58 15ms echo reply
2 2800:3f0:4001:810::200e 56 58 15ms echo reply
sent=3 received=3 packet-loss=0% min-rtt=15ms avg-rtt=18ms max-rtt=24ms
Here is what I get in an OSx machine:
# /usr/sbin/netstat -f inet6 -rn
Routing tables
Internet6:
Destination Gateway Flags Netif Expire
default fe80::e68d:8cff:fedc:e260%en0 UGc en0
... Lots of other things
# ping6 fe80::e68d:8cff:fedc:e260%en0
PING6(56=40+8+8 bytes) fe80::3285:a9ff:fe3e:394d%en0 --> fe80::e68d:8cff:fedc:e260%en0
16 bytes from fe80::e68d:8cff:fedc:e260%en0, icmp_seq=0 hlim=64 time=0.361 ms
16 bytes from fe80::e68d:8cff:fedc:e260%en0, icmp_seq=1 hlim=64 time=0.371 ms
^C
--- fe80::e68d:8cff:fedc:e260%en0 ping6 statistics ---
2 packets transmitted, 2 packets received, 0.0% packet loss
round-trip min/avg/max/std-dev = 0.361/0.366/0.371/0.005 ms
> ping6 2800:3f0:4001:810::200e
PING6(56=40+8+8 bytes) 2001:1284:f005:cc2f:345d:f4ed:d2f4:bdef --> 2800:3f0:4001:810::200e
^C
--- 2800:3f0:4001:810::200e ping6 statistics ---
2 packets transmitted, 0 packets received, 100.0% packet loss
You have same /64 subnet on both ether1-gateway and ether2-master-local, that’s not right. Try either setting prefix hint for DHCPv6 client to e.g. ::/60 to get more subnets, or uncheck the option to get address (which seems that you have enabled).
I don’t have any rules in firewall since I was planning to setup them later. Shouldn’t it be working?
Yes, my ISP only provides a dynamic /64 subnet. I have unchecked the option to get address but even after a reboot, it doesn’t seem to make any difference. I still can’t ping or access anything from my internal network.
> /ipv6 dhcp-client print
0 ether1-... bound prefix 2001:1284:f004:aee1::/64, 23h51m2s
All the rest of my v6 configuration is pretty much just firewall rules.
The above works with a standard /64 prefix as well. The WAN interface just uses link-local addressing to reach the Internet, and if the router itself needs to go out on the Internet (say, for a DNS lookup) then it will just use it’s LAN address to generate the packet.
For some reason, the export doesn’t indicate it, but in the GUI, I configured the address to be ::1/64 - the from-pool=Comcast part fills in the routable /64 prefix.
The default GW is set by the “use default gateway” checkbox on the dhcpv6-client configuration. I do have a couple of static routes, but they are related to something extra that I’m doing. A basic functional IPv6 configuration doesn’t need any static routes.
You DO want to put firewall rules, though - if you have none, then all of your devices are directly reachable via IPv6 from the Internet, so you will want at least a basic firewall rule set. Here’s a basic one based on mine (with some specific-to-me stuff removed):
/ipv6 firewall filter
add chain=forward comment="Allow existing connections" connection-state=established,related
add chain=forward protocol=icmpv6
add chain=forward comment="Allow whitelisted hosts and networks" src-address-list=Whitelist
add action=drop chain=forward comment="Block Internet from new inbound connections." in-interface=WAN
add chain=input comment="Allow Existing Connections" connection-state=established,related
add chain=input comment="Permit ICMP" protocol=icmpv6
add chain=input comment="Trust Whitelisted Hosts" src-address-list=Whitelist
add chain=input comment=\
"Allow DHCPv6 replies on WAN from link-local" dst-address=\
fe80::/16 dst-port=546 in-interface=WAN protocol=udp src-address=fe80::/16
add action=drop chain=input comment="Block New Connections from Internet" in-interface=WAN
I have lets say philosophical objection to this. If you block new connections from WAN to LAN, then it makes it (in a way) worse than with IPv4. At least with IPv4, if users are lucky enough to get public addresses, they can use UPnP and let internal devices open ports for direct communication as needed.
With IPv6, even the fridges will have public addresses, but with dissallowed incoming on router, they will still have hard time participating in FridgeNet dynamic P2P network or something.
There’s a Port Control Protocol (RFC6887) which looks like it’s able to open ports in firewall, but implementation wise, it’s still mostly theoretical.
Well, this is my home network, so I’m not enforcing anything on anyone - and usually, the big problem in IPv4 is when two peers both of which are behind NAT wish to communicate - neither can successfully receive a TCP/SYN handshake from the other side - both hosts’ firewalls are waiting for their local client to initiate the connection / don’t know which internal machine the SYN handshake is for.
This isn’t as big a deal in IPv6 with UDP streams because both sides can start transmitting which will lead to both firewalls getting a stateful entry generated - both hosts can directly address each other. Desirable inbound TCP ports can be allowed as well, because the target of the inbound request is known (has its own unique public routable address). But in general, do you really want to leave every device on your network open to direct packet requests on all ports? That just doesn’t seem wise.
UPnP could be made to work on a stateful IPv6 firewall just as easily as an IPv4 - and I wouldn’t say it’s “worse” because at least the hosts have the real direct addresses of each other, so no clever workarounds are required for cases where both sides have private addresses. No “fibs” need to be made (NAT) - only the policy portion must be addressed. Now, the UPnP can simply say "I’m host XXXXXXX and I want to receive traffic on port X, so the firewall can create a dynamic “permit” rule for this - no pinholes need to get made, and the LAN host doesn’t need to figure out what “public IP” the router is using. The host just uses its own address.
Eventually I will set firewall rules but first I’m trying to get it working. I checked my configuration again following your previous post but I still can’t ping or access any external ipv6 addresses from my internal network.
An ipv6 address is assigned correctly and I can ping internal hosts.
Also, I tried to connect a machine directly to my ISP’s modem and ipv6 worked correctly. So it must be something wrong in mikrotik configuration.
At this point, I have no clue about what is wrong.
I’m curious to know why that is. The WAN interface of a router can work just fine passing traffic to the default GW using its link-local (fe80: address.
I’ve been looking for 8 days and I came across this subject which is identical to my problem.
It is strictly the same in that I can ping from the mikrotik router to the outside, I can ping from one of my machines to another, but I cannot ping from a machine to the internet.
Windows or mac osx says I don’t have an internet connection.
My setup looks good because the worst part is that it worked before.
I have a modem which only supports DMZ, with which it is not possible to have a PPPoe connection because the credentials are automatic.
My network is therefore in DMZ ipv4 and DMZ ipv6.
have tried everything and I don’t know what to do.
I get a prefix xxx: b301 / 56 and in the DMZ I have xxx: b302 / 64 with the gateway xxx: b301: xxx: xxx: xxx
The only thing i did in mikrotik that worked fine is enter a static ipv6 address like xxx: b302 :: 1/64 on ether2 which is my lan but linked to the mikrotik bridge, and allow advertising.
ether1 is the WAN.
Nothing works anymore, I wonder why it was working well, but I admit that my ISP just deployed IPV6 and that there is something that may have changed in them.
Simply in France the ISPs are not really trained to answer his questions, it is light years away from their skills.
But I would like to know if you have solved the problem to give me a lead and how to investigate.
Clarification to the author of the subject, when I connect directly to the modem, ipv6 works like you! I have the impression that something is not working in DMZ.
Hello!!
I just noticed that I have exact the same problem.
Yesterday I made a post about my issue. I will link here just because I already posted my configuration and the full issue there. (I don’t want to hijack the thread, I will be monitoring both). http://forum.mikrotik.com/t/help-troubleshooting-ipv6/148862/1
I have the same problem described in this thread (ISP with only a /64, Mikrotik and devices with IPv6, Mikrotik can ping IPv6 internet but internal devices can’t).
If I try your setup the dhcp-client in the “request=prefix” doesn’t work (stuck in searching), only “request=address” works, so for me it’s not clear what you are suggesting since the subnet is only one (the ISP /64).
Am I missing something?
ISP of course is saying that it’s my problem, nothing they can do (of course not…)
