IPv6 client and server at home
I just got a hEX router and am having a hard time getting things configured correctly when it comes to ipv6. my setup is (Charter Spectrum ISP) > (Cable Modem) > (hEX) > (wired and wireless clients). My goal is for clients to get both a private IPv4 and IPv6 address. So far I have setup an IPv6 client, servers, and pools like so:
[admin@MikroTik] > /ipv6 dhcp-client print
Flags: D - dynamic, X - disabled, I - invalid
 #    INTERFACE                STATUS        REQUEST                PREFIX                                                           ADDRESS
 0    ether1-WAN               error         address                2600:6c5a:6580:16d5::/64, 4d17h20m3s                             2600:6c5a:7004:200:4d76:235b:d12f:68d9, 4d17h20m3s
                                             prefix
[admin@MikroTik] > /ipv6 dhcp-server print
 #    NAME                                               INTERFACE                                               ADDRESS-POOL                                               PREFERENCE LEASE-TIME
 0    server-lan                                         lan_bridge                                              pool-lan                                                          255 3d
 1    server-guest                                       guest-wifi                                              pool-guest                                                        255 3d
[admin@MikroTik] > /ipv6 pool print
Flags: D - dynamic
 #   NAME        PREFIX                                      PREFIX-LENGTH EXPIRES-AFTER
 0   pool-lan        fd21:72a3:c952:856b::/64                               64
 1   pool-guest        fd16:e708:5d28:e964::/64                               64
The client setup was largely based on https://www.netdaily.org/tag/mikrotik-ipv6-home-example/ On the server side, I saw some references online to also needing to setup ND but this was there by default:
[admin@MikroTik] > /ipv6 nd print
Flags: X - disabled, I - invalid, * - default
 0  * interface=all ra-interval=3m20s-10m ra-delay=3s mtu=unspecified reachable-time=unspecified retransmit-interval=unspecified ra-lifetime=30m hop-limit=unspecified advertise-mac-address=yes
      advertise-dns=no managed-address-configuration=no other-configuration=no
With this in place I do not get an IPv6 address on any of my clients.
Here’s a little more info that might help:
[admin@MikroTik] > /interface print
 #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU MAC-ADDRESS
 0  R  ether1-WAN                          ether            1500  1596       2026 B8:69:F4:91:1C:17
 1  RS ether2-master                       ether            1500  1596       2026 B8:69:F4:91:1C:18
 2  RS ether3                              ether            1500  1596       2026 B8:69:F4:91:1C:19
 3  RS ether4                              ether            1500  1596       2026 B8:69:F4:91:1C:1A
 4  RS ether5                              ether            1500  1596       2026 B8:69:F4:91:1C:1B
 5  R  guest-wifi                          vlan             1500  1592            B8:69:F4:91:1C:18
 6  R  guest_bridge                        bridge           1500 65535            00:00:00:00:00:00
 7  R  lan_bridge                          bridge           1500  1596            B8:69:F4:91:1C:18
[admin@MikroTik] > /interface bridge print
 0  R name="guest_bridge" mtu=auto actual-mtu=1500 l2mtu=65535 arp=enabled arp-timeout=auto mac-address=00:00:00:00:00:00 protocol-mode=rstp fast-forward=yes priority=0x8000 auto-mac=yes
      admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
 1  R name="lan_bridge" mtu=auto actual-mtu=1500 l2mtu=1596 arp=enabled arp-timeout=auto mac-address=B8:69:F4:91:1C:18 protocol-mode=rstp fast-forward=yes priority=0x8000 auto-mac=yes
[admin@MikroTik] > /interface vlan print
Flags: X - disabled, R - running, S - slave
 #    NAME        MTU ARP             VLAN-ID INTERFACE
 0 R  guest-wifi        1500 enabled              16 ether2-master
In case it helps, the guest stuff is my take on an isolated network for guests and IoT devices. Its intended that devices on that network can access the internet but not anything on the standard lan or standard wired network.
