IPv6 configuration using Starlink
I don’t think this is a Starlink issue, I think this is a user (me) issue.
I have configured IPv6 as shown in the following ‘export’ script. Below are the results of various print statements showing the actual results (two octets have been replaced for safety)
I am able to ping6 the IPv6 address assigned to the Starlink (WAN) interface from a server on the Internet. I am NOT able to ping6 the IPv6 address assigned to the LocalLAN (bridge) interface nor systems on my local LAN. Systems on my local network receive IPv6 addresses via SLAAC and can ping6 each other as well as the LocalLAN address. They cannot ping6 the Starlink interface nor my server on the Internet.
This appears to me to be a routing/gateway issue, but I have no idea what I’ve failed to do and/or done wrong. Can someone take pity on me and point out my errors?
/ipv6 export
# jun/08/2023 21:24:42 by RouterOS 7.9.2
# software id = 2CK0-7VW7
# model = RBD53iG-5HacD2HnD
# serial number = HDJ08K493X6
/ipv6 pool
add name=IPv6Pool prefix=::/64 prefix-length=64
/ipv6 dhcp-client
add interface=Starlink pool-name=IPv6Pool prefix-hint=::/64 request=prefix
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="accept neighbor discovery" dst-port=5678 protocol=udp
add action=accept chain=input comment="accept DHCPv6-Client prefix delegation" dst-port=546 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/ipv6 nd
add advertise-dns=no advertise-mac-address=no interface=Starlink ra-lifetime=none
add advertise-mac-address=no dns=2606:4700:4700::1112,2606:4700:4700::1002 interface=LocalLAN ra-interval=20s-1m
/ipv6 settings
set accept-redirects=no accept-router-advertisements=yes
/ipv6 dhcp-client print
Columns: INTERFACE, STATUS, REQUEST, PREFIX
# INTERFACE STATUS REQUEST PREFIX
0 Starlink bound prefix 2605:XXXx:YYYf:8100::/56, 15m17s
/ipv6 address print
Flags: D - DYNAMIC; G, L - LINK-LOCAL
Columns: ADDRESS, INTERFACE, ADVERTISE
# ADDRESS INTERFACE ADVERTISE
0 DL fe80::4aa9:8aff:fe19:f9e2/64 LocalLAN no
1 DL fe80::4aa9:8aff:fe19:f9e1/64 Starlink no
2 DG 2605:XXXx:YYY0:8389:4aa9:8aff:fe19:f9e1/64 Starlink no
3 DG 2605:XXXx:YYYf:8100:4aa9:8aff:fe19:f9e2/64 LocalLAN no
4 DG ::4aa9:8aff:fe19:f9e2/64 LocalLAN no
/ipv6 route print
Flags: D - DYNAMIC; A - ACTIVE; c, d, g, y - BGP-MPLS-VPN; + - ECMP
Columns: DST-ADDRESS, GATEWAY, DISTANCE
DST-ADDRESS GATEWAY DISTANCE
DAg+ ::/0 fe80::c2c1:c0ff:fe2f:beb1%LocalLAN 1
DAd+ ::/0 2605:XXXx:YYY0:8389::1 1
DAg+ ::/0 fe80::200:5eff:fe00:101%Starlink 1
DAc ::/64 LocalLAN 0
DAc 2605:XXXx:YYY0:8389::/64 Starlink 0
DAd 2605:XXXx:YYYf:8100::/56 1
DAc 2605:XXXx:YYYf:8100::/64 LocalLAN 0
DAc fe80::%Starlink/64 Starlink 0
DAc fe80::%LocalLAN/64 LocalLAN 0
/ipv6 nd print
Flags: X - disabled, I - invalid; * - default
0 * interface=all ra-interval=3m20s-10m ra-delay=3s mtu=unspecified reachable-time=unspecified retransmit-interval=unspecified ra-lifetime=30m ra-preference=medium
hop-limit=unspecified advertise-mac-address=yes advertise-dns=yes managed-address-configuration=no other-configuration=no dns="" pref64=""
1 interface=Starlink ra-interval=3m20s-10m ra-delay=3s mtu=unspecified reachable-time=unspecified retransmit-interval=unspecified ra-lifetime=none ra-preference=medium
hop-limit=unspecified advertise-mac-address=no advertise-dns=no managed-address-configuration=no other-configuration=no dns="" pref64=""
2 interface=LocalLAN ra-interval=20s-1m ra-delay=3s mtu=unspecified reachable-time=unspecified retransmit-interval=unspecified ra-lifetime=30m ra-preference=medium
hop-limit=unspecified advertise-mac-address=no advertise-dns=yes managed-address-configuration=no other-configuration=no dns=2606:4700:4700::1112,2606:4700:4700::1002 pref64=""
