The “pool-prefix-length” is meant to be the length of the prefixes which you want to draw from the address pool, not the prefix length that your ISP assigns. Most of the time, you want those address ranges to be significantly smaller (bigger prefix length), so that you have multiple prefixes that can be assigned to separate subnets. If you do not need to delegate prefixes to other routers which in turn need several prefixes, you should probably use a pool-prefix-length of 64. Then you can draw from the pool wherever you need an IPv6 prefix, for example “/ipv6 address”.
so I could do this If I had other routers behind my router but not when using just one router. Yes, I can see how that would work in a larger network , but it is a bit disappointing to not be able to define the pools manually.
I can indeed assign an address to every vlan address, and then the autodiscovery will distribute to the rest of the devices.
It becomes a bit complicated, or rather impossible, if you have a need for prefixes with different lengths, because the pool can have just one pool-prefix-length and you can’t take a chunk out of the pool to create a “sub” pool with a different prefix length. So if you need /60 prefixes for prefix-delegation to other routers, you cannot assign /64 prefixes from the same pool to directly attached networks. Though if you have enough addresses, you can simply assign /60 prefixes also to LANs. It’s “wasteful”, but you weren’t going to use the full /48 anyway, were you?
no, no, I do not intend to have 65000 subnets at home. , at least, you never know …
I guess I expected something before I fully understood how it should be working, so now I have adapted my expectation and have a working setup and understand how to go from here.
Thanks again.
