Hello.
I have my IPv6 setup at home, I am trying to switch all the management from IPv4 from IPv6 but I am facing an issue.
I have a Mikrotik HAP AC2 as main router that works perfectly fine, routing my prefix via BGP by my CHR in my POP.
I then have 2 CRS326 at home, I have enabled IPv6 on them, they do get the IPv6 ip addresses via the RA from the HAP but for an unknown reason they are not adding the default route as all the other devices are doing.
IPv6 forwarding is disabled on the CRS so it should not impact this part (they are not doing any IPv4 or IPv6 routing, purely L2).
Any idea on what could cause this ?
This is the only conf I have in /ipv6 on the CRS (The 2 have the same issues)
[kedare@ESMLG1-LR1-CRS1] /ipv6/address> print
Flags: D - DYNAMIC; G - GLOBAL, L - LINK-LOCAL
Columns: ADDRESS, INTERFACE, ADVERTISE
# ADDRESS INTERFACE ADVERTISE
0 DL fe80::2ec8:1bff:feda:xxxx/64 bridge no
1 DL fe80::2ec8:1bff:feda:xxxx/64 vlan1-mgmt no
2 DG 2001:xxx:xxx:xxx:2ec8:1bff:feda:xxxx/64 vlan1-mgmt no
[kedare@ESMLG1-LR1-CRS1] /ipv6/address> /ipv6 export
/ipv6 nd
/ipv6 settings
set accept-router-advertisements=yes forward=no
