IPv6 deployment on individual /64
We are currently attempting to deploy ipv6 in our network. We plan to provide a /64 to each of our customers.
What would be the best setup for it? DHCP/SLAAC are not needed, as the services will come preconfigured with static ip and gw.
I am currently thinking of simply creating a gateway on the router for each /64.
But how to scale that? It might work ok on 2000 customers, but will it be stable at 20.000?
Is there a better solution to doing this?
Maybe we should use a virtual router for ipv6 only?
I don’t know what’s the best solution for your problem. But about this:
Please don’t, that’s what evil ISPs do. Even though /64 is insane amount of addresses, it’s only one subnet and it can’t be divided into smaller ones without creating compatibility problems.
https://www.ripe.net/publications/docs/ripe-690#4-2--prefix-assignment-options
I’m with Sob here: just don’t give a single /64 to your customers: it’s plain evil, and will cost you dearly in the future - both in maintenance and customer churn.
Yup, the recommendation is to allow up to a /56 to be requested via DHCPv6-PD. The absolute smallest I’d go is a /60 for residential. It gives the customer the ability to provide a normal LAN, a guest network and VPN without compatibility breaking small subnets.
