Hi, I’m interested to know if anyone is already deploying, at least in beta, IPv6 to customers?
Right how we’re doing only IPv4 over L2TP+IPSec, I’d like to provide IPv6 to customers. I will request a /48 tunnel to Hurricane Electric for the test.
What do you use for delegating an IPv6 prefix? There are several alternatives: DHCPv6-PD, Framed-IPv6-Prefix, Framed-IPv6-Route, Delegated-IPv6-Prefix, etc, and I’d like to provide a solution that will work for customers with a single machine and for customers with a Mikrotik CPE (something that will allow me to have a single device for the wireless link and an ethernet port for the customer).
I have tried DHCPv6 (ROS doesn’t request for an IP), Framed-IPv6-Prefix (Linux PPP doesn’t support it), and RADVD (ROS doesn’t see it over the PPP link)..
Just for more detail, this is an RA from 5.6, and it does indeed already advertise DNS via RAs. The prerequisite is that you have an IPv6 DNS server listed under “/ip dns”, that’s where the router takes the addresses from that it advertises in the RA.
But it bypasses DNS cache on router. And I guess it won’t work very well if I put router’s own address as the only IPv6 resolver under “/ip dns”. Well, if there are other resolvers using IPv4, then worst case should be some delays, if router tries to ask itself first. But in case my ISP is IPv6-only (I agree, not likely very soon) so there are no IPv4 resolvers, then it means I can’t use cache. IMHO the address of DNS resolver to be advertised to clients should go somewhere under “/ipv6 nd”.
DNS under RA is working but it’s useless, The bulk of clients are Windows and Windows doesn’t listen to DNS under RA.
IPv6 deployment under ROS is painful but doable, You can’t do v6 under ROS 4.x if you need to use dynamic routing and under ROS 5.x you still can’t do DHCPv6-PD which we are told is coming but who knows when (See http://developer.valvesoftware.com/wiki/Valve_Time)
We support IPv6 to all of our clients at the moment and thats only possible due to a high level of API automation in order to handle the 6to4 tunnels and IPv6 lan address’s on the clients CPE
Just my opinion, I’m sure I don’t know nearly as much as the ROS developers, but I think they’re missing the point somehow. IPv6 support is still very basic and they don’t seem to be worried about it. The problem is that RIGHT NOW is when ISPs are looking for IPv6 alternatives, especially in the CPE market, and MT doesn’t even support DHCPv6-PD yet.
I know Mikrotik is a small company and their resources are limited, but I think refocusing their development and setting IPv6 as TOP priority for just a couple of months would get us a nice, working, full IPv6 support. And, you know, the early bird gets the worm! The hardest part (IPv6, routing, and firewalling) is already done.
That’s exactly right, IPv6 in ROS 3.x and 4.x was completely useless and was not going to be fixed by MT until ROS 5.x, Even then they have clearly overlooked the access part of it, Stable IPv6 BGP is pointless without a way to deliver it to clients, DHCPv6-PD is such a key point I struggle to make sense of MT’s IPv6 plans, PD should have arrived the same time that PPPv6 support did but here we are waiting with baited breathe for it
I was going to be giving a IPv6 talk at a summit later this year but scheduling put a stop to that. Part of my talk was going to use MT as an example for misfeatures on how NOT to do IPv6
