IPv6 DHCP Relay with PD not installing route
Hi
I try to use a Mikrotik CCR as a IPv6 Gateway for a bigger network. Client CPE gets its prefix via DHCP6 PD. The CCR has a DHCP6 Relay configured but does not install the prefix it hands out to the Customer CPE into the local routing table. When I configure the DHCP Server locally on the CCR the route gets added to the table.
What I am lokich for is that the relay behaves the same as the local server:
http://wiki.mikrotik.com/wiki/Manual:IPv6/DHCP_Server#Enabling_IPv6_Prefix_delegation
→ DHCP-PD also installs route to assigned prefix into IPv6 routing table
I have not found a config option to do so. Anyone has the same problem.
Regards
Matthias
Same problem here!
mikrotik install route on the server, where is DHCP-SERVER, but correct behavior is to install route there, where is DHCP-RELAY.
Hello. Any chance to fix this problem?
Still have issue on RouterOS v6.40.4.
Adding the route for the relayed prefix is still not available in 6.44. Mikrotik, please fix! This makes IPv6 DHCP relay pretty useless without it.
if you encounterd a bug contact Mikrotik support.
I ended up enabling DHCP logging and writing a script to read the log and add the prefix that way. I have the script on a scheduler and running every minute. Quite a pain, but it was the only real automated way I could think of to do it.
Hi sawilkinson2,
Did you ever get this to work in a native way? I currently do it with a script/api call from our dhcp server. Not great, but works.
could you please share the script? that would be really nice.
it would be really nice to share the script, we have same issue
Will this feature (IPv6 DHCP Relay installing Prefix Route) perhaps be implemented in RouterOS 7?
