ipv6 disabled but I see traffic in torch
I have CCR2116-12G-4S+ (7.11) with ipv6 disabled, while in torch I can see ipv6 traffic.
I don’t think it should be there. how to completely disable ipv6 on mikrotik?
Disabling IPv6 on the router does not disable IPv6 on all your network devices.
So you may still see traffic that others attempt to setup.
When you disable management via http, do you also disable http on all your devices?
SOLUTION: Turn off the device.
