I have first experience with Ipv6 on mikrotik 5.11 in “client mode”. It’s horrible …
At first:
I need accept router-advertisiments on routers. CPE doesn’t have default route without RA (ospf is not applicable). It is linux problem, http://tldp.org/HOWTO/Linux+IPv6-HOWTO/proc-sys-net-ipv6..html (if forwarding, accept ra is disabled). I need write access for this value … may be in winbox, or CLI only.
At second:
how i find out DUID? In no way … Only on DHCP server in log messages, or by studying tcpdump. Or at least that was in the manual method of DUID creation. In my RB1100AH is created from MAC address ether12 - why? Why not from first interface? Or last interface? Or not from routerboard serial number? Simply predictable way.
At third:
I need stateless configuration. IP address (and default route) for devices on LAN side from RA, DNS servers from stateless DHCP. Using statefull DHCP for this is unnecessary in most cases.
So take the prefix via DHCP-PD and assign to the LAN interface. And stateless DHCP server, of course.
But even if statefull configuration should be able to take the prefix /64 for client from PD and allocate him /64 too, from same segment. Why not?
Or receive eg. /62 from PD and asign four /64 segments on four idependent interface.
summary:
wan interface - accept RA (with default route).
lan interface - accept prefix from PD and using it as global address.
dhcp server - stateless configuration.
But: without accept RA router doesn’t default route! Global IP address may be absent, but default route not. I have to configure statically or using OSPFv3 (not usable in every situation).
If absent default route in router, why prefix delegation for LAN devices? The useless. I’m talking about CPE, not about “core” routers.
Thanks.
It would also be appropriate if it was persistent DUID to survive a reinstallation of ROS. Routerboard it meets (in most cases, network intefaces is persistent), but x86 not. But i have not tried it.
Is there a method to specify DUID for a DHCP client? The problem is my local ISP (IPv6 DHCP server of it) checks if request DUID corresponds device MAC address, and if not it responds #6 - no prefixes available.
I can switch ports or port MACs in this case but, I think, there should be the way to change DUID for an each IPv6 DHCP client because it’s RoS (there’s no more criminal when manipulating with MAC addresses).
