With the current Version of WinBox (3.37) in the IPV6 Firewall NAT window, if you use the NETMAP Action the “to-address” field is missing. But you have to use it if you want to create this entry.
If you create this rule with the Command Line the NETMAP is not working.
I’m using ros v7.7, the netmap is configueable but when doing nat, only the first ipv6 address is used.
Like:
netmap 1:2:3:4::/64 to 4:3:2:1::/64, all ipv6 addresses will be snat to 4:3:2:1:: , no matter what source address is.
Yes, that’s exactly what I meant by “it doesn’t work”. IPv6 prefix translation is an important feature when it comes to using IPv6 in companies. I wonder why MikroTik is not more behind this…
