IPV6 Firewall
Hi guys, for various reasons i managed to lose the back up and config for my rb4011, and whilst i have managed to get it back up and running, i am having a couple of issues with the IPv6 firewall rules.
I looked at my previous posts on here and copied them but for some reason, running the inline test, i cannot get icmpv6 to work.
Here is my current config of the firewall..
/ipv6 firewall address-list
add address=::/128 comment=defconf:lo list=badipv6
add address=fec0::/10 comment=site-local list=badipv6
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::/4 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=input
    established,related,untracked
add action=drop chain=input comment="defconf:drop invalid" connection-state=\
    invalid
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
add action=accept chain=input comment="defconf:accept IKE" dst-port=500,4500 \
    protocol=udp
    ipsec-ah
add action=accept chain=input comment="defconf: accept ipsecESP" protocol=\
    ipsec-esp
    icmpv6
    "defconf:accept all that matches ipsec policy" ipsec-policy=in,ipsec
    !LAN
    connection-state=invalid
    "defconf:drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop=limit=1" \
    icmpv6
add action=accept chain=forward comment="deeconf: accept IKE" dst-port=\
    500,4500 protocol=udp
    ipsec-ah
add action=accept chain=forward comment="defconf:accept ipsec ESP" protocol=\
    ipsec-esp
    !LAN
Hopefully you guys might be able to spot something i have messed up (again!)
Cheers!
I don’t see anything breaking icmpv6. But the very first rule makes all other chain=input rules useless, because it accept everything. And second last rule allows incoming connections to LAN, which you may or may not want, but if you do, then last rule is useless.
Try enabling logging for the invalid rule. I’ve had some problems with lan-to-lan connections which were flagged invalid.
Thanks.
Thing is, i lose ipv6 completely if i remove the first rule..?
Should there be another rule i need to add?
I missed a thing, you broke default config. This rule:
add action=drop chain=input comment="defconf: drop invalid" connection-state=established,related,untracked
should have action=accept (and comment is wrong too).
Thanks,
changed that and removed first rule but still no icmp being passed.
With original config, router accepted all traffic to itself, it didn’t block anything at all. And forwarded traffic could be affected only by:
So you can try to temporarily disable this rule (or add logging to it, as previously suggested). If it still doesn’t help, the next question is how exactly you test it.
Ok, temporarily disabled and still no go.
I am using https://ipv6-test.com/ on a macbook & W10 laptop with various browsers.
Oddly, i have just used this test on my iphone (using Safari), and it seems to work ok!?
Then also check firewall on those devices. I don’t know about Mac, but if the testing site sends echo request (ping), then Windows block it by default.
Thanks.
Just checked those and all seems to be set up properly.
I tried another test site and got this, so i have no idea whats going on.
Also, there doesn’t seem to be any packets at all recorded across most of the rules…
Just tried comparing configs from last year and now and it seems things have changed a bit so not sure if my current config is correct anyway?
set [ find default-name=ether1 ] comment=Internet
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge lease-time=1d name=defconf
/ipv6 dhcp-server
add address-pool=Pool1 interface=bridge name=server1
/ipv6 pool
add name=pool1 prefix=::/64 prefix-length=64
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
/interface detect-internet
set detect-interface-list=all
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
    192.168.88.0
add address=159.xxx.xxx.xxx/30 interface=ether1 network=159.xxx.xxx.xxx
/ip dhcp-client
set allow-remote-requests=yes cache-max-ttl=1d servers=\
    1.1.1.1,2606:4700::1111,1.0.0.1,2606:4700::1001
/ip dns static
    invalid
    in-interface-list=!LAN
    ipsec-policy=out,ipsec
add distance=1 gateway=159.xxx.xxx.xxx
/ipv6 address
add address=2a00:xxxx:yyyy:1::1 interface=bridge
add address=2a00:xxxx:yyyy::2 interface=ether1
add action=accept chain=input comment="defconf: accept" connection-state=\
    invalid
add action=accept chain=input comment="defconf: accept ICMPv6" \
    connection-state="" protocol=icmpv6
    udp src-address=fe80::/16
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
add action=drop chain=forward comment="defconf: Drop Invalid" \
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/ipv6 nd
set [ find default=yes ] advertise-dns=no advertise-mac-address=no interface=\
    bridge managed-address-configuration=yes other-configuration=yes
/ipv6 nd prefix
add autonomous=no interface=bridge prefix=::/0
/ipv6 route
add distance=1 gateway=2a00:xxxx:yyyy::1
/system clock
set time-zone-name=Europe/London
/tool mac-server
/tool mac-server mac-winbox
Just to add, i realised my IPV6 DNS was incorrect but after correcting it, still the same,
You can view the default config for the device by executing: /system default-configuration print
The default config shown by that command is updated by upgrading the RouterOS version, so it will be the latest version if your router has the latest version.
Copy and paste the IPv6 firewall section to a text editor, delete all your IPv6 firewall rules and paste in the section from the default-configuration. Then you will have the factory IPv6 firewall rules back, which should work for everything.
Hi, thanks.
Tried that but still not working!
As i said, the weird thing is, it works fine on latest ios.
I have even tried other laptops and they wont allow icmp either.
Just to add, i am not getting any ipv6 entries in the DNS cache as well.
The rules are same for all devices, so if one works and another doesn’t, I’d focus on that device. Packet sniffer is your friend, you can verify what is coming to device, if it responds to it, etc.
Some ISPs have broken IPv6 deployment leading to reachability/ICMPv6 problems, same thing with my IPv6 ISP.
Cheers Guys
Sob:
It is weird tbh, as looking at the ipv6 connections, there is nothing at all for protocol 58.
However, if i run the test on ios, i get a connection at port 58, but it shows a connection to icmpv6 but with a source port & destination port as 0?
Dark: I am running a leased line and as far as i am aware, IPV6 is running ok with them, but i will check.
Ok, i have just run a traceroute to Googles IPV6 DNS and that comes back ok, as well as Cloudfare DNS.
With that, i am assuming the web based version of the test site has problems.
I am also starting to get DNS entries (AAAA) after i moved my ipv6 DNS server to the top.
Try ping to your address from outside. If you don’t have any device from which you can test it, there are various websites that offer pings from their servers.
DNS doesn’t have to do anything with transport protocol used by server. Client device asks for A or AAAA records depending on what protocol it has available and it works even if you don’t have any IPv6 DNS server at all, because even IPv4 one can answer AAAA queries.
