Is there any chance for IPv6 version of IPSec? I would like to have secured OSPFv3 ![]()
When we can expect this feature?
best regards
best regards
I’m running IPsec between 3 routers, in a triangle like topology. All traffic from one to the other is IPSEC’ed and i run a EOIP tunnel over that. Including OSPFv2 and v3. And IPv6 will run over that all day long.
Don’t know if that will work for you or not. But it does for me.
Thank you. Are you sure your IPv6 traffic is encrypted? If I can’t set IPv6 peers and polices I don’t see any way to do this but maybe I missed something.
best regards
Yes it is.
Its running over the EOIP tunnel
And anything that moves from my router to another router is ipsec by IP.
