Good morning
I’m having some trouble with getting the IPv6 MTU Discovery to work. If I do not set the MTU at 1492 in the router advertisement most websites will not load. I’m using a PPPoE connection with an automatic MTU of 1492. I understand that some servers do not accept ICMPv6. But shouldn’t my own client automatically switch to an MTU to 1492 when reaching my WAN since my own router knows that the WAN path is at 1492 MTU? Why doesn’t it except if I state an MTU of 1492 in the router discovery?
What am I doing wrong?
add admin-mac=2C:C8:1B:FD:72:F8 auto-mac=no comment=defconf name=bridge pvid=900 vlan-filtering=yes
/interface vlan
add interface=bridge name=Guest_vlan vlan-id=40
add interface=bridge name=IoT_vlan vlan-id=20
add interface=bridge name=Server_vlan vlan-id=30
add interface=bridge name=Trusted_vlan vlan-id=10
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-proximus user=xxxxx@PROXIMUS
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=pool_trusted ranges=10.0.1.100-10.0.1.254
add name=pool_IoT ranges=10.0.2.100-10.0.2.254
add name=pool_guest ranges=10.0.4.100-10.0.4.254
add address-pool=pool_trusted interface=Trusted_vlan lease-time=1w name=DHCP_trusted
add address-pool=pool_IoT interface=IoT_vlan lease-time=1w name=DHCP_IoT
add address-pool=pool_guest interface=Guest_vlan lease-time=1d name=DHCP_guest
/port
set 0 name=serial0
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether3 pvid=10
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether4 pvid=900
add bridge=bridge interface=ether5 pvid=10
add bridge=bridge interface=sfp1
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether2 pvid=10
/interface bridge vlan
add bridge=bridge tagged=bridge,ether4 untagged=ether5,ether3,ether2 vlan-ids=10
add bridge=bridge tagged=bridge,ether4,ether5 vlan-ids=20
add bridge=bridge tagged=bridge,ether4 vlan-ids=30
add bridge=bridge tagged=bridge,ether5,ether4 vlan-ids=40
add interface=pppoe-proximus list=WAN
add interface=Trusted_vlan list=LAN
add interface=IoT_vlan list=LAN
add interface=Guest_vlan list=LAN
add interface=Server_vlan list=LAN
add address=10.0.1.1/24 interface=Trusted_vlan network=10.0.1.0
add address=10.0.2.1/24 interface=IoT_vlan network=10.0.2.0
add address=10.33.3.1/24 interface=Server_vlan network=10.33.3.0
add address=10.0.4.1/24 interface=Guest_vlan network=10.0.4.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-server lease
add address=10.0.1.254 client-id=1:3c:7c:3f:27:f7:e0 mac-address=3C:7C:3F:27:F7:E0 server=DHCP_trusted
add address=10.0.1.0/24 dns-server=1.1.1.1,1.0.0.1 gateway=10.0.1.1
add address=10.0.2.0/24 dns-server=1.1.1.1,1.0.0.1 gateway=10.0.2.1
add address=10.0.4.0/24 dns-server=1.1.1.1,1.0.0.1 gateway=10.0.4.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
add action=accept chain=input comment="accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=input comment="drop invalid" connection-state=invalid
add action=accept chain=input comment="accept ICMP" protocol=icmp
add action=accept chain=input comment="Allow trusted vlan" in-interface=Trusted_vlan
add action=drop chain=input comment="Drop any"
add action=accept chain=forward comment="accept established,related" connection-state=established,related
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=accept chain=forward comment="Accept LAN to WAN" in-interface-list=LAN out-interface-list=WAN
add action=drop chain=forward comment="Drop any"
add action=masquerade chain=srcnat comment=masquerade ipsec-policy=out,none out-interface-list=WAN
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 address
add from-pool=GA_Pool interface=Trusted_vlan
add from-pool=GA_Pool interface=IoT_vlan
add from-pool=GA_Pool interface=Server_vlan
add from-pool=GA_Pool interface=Guest_vlan
/ipv6 dhcp-client
add interface=pppoe-proximus pool-name=GA_Pool request=prefix
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="accept established,related" connection-state=established,related
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept HIP - to research if really needed" disabled=yes protocol=139
/ipv6 nd
set [ find default=yes ] dns=2606:4700:4700::1111,2606:4700:4700::1001 mtu=1492
/system clock
set time-zone-name=Europe/Brussels
/tool mac-server
/tool mac-server mac-winbox
