I’m sure I’m making a n00b error here but I can’t work out what.
RouterOS is v6.49.13 (stable) now 7.12.1 and the machine is hEX S RB760iGS r2
I have a pppoe connection to fibre. It had ipv4 and ipv6, fixed assignments on the pppoe account.
The ipv4 is a /29 and is working fine. The clients are manually assigned. It’s not using any dhcp with ipv4.
This was configured via the quick set menu, mode router and port ether1. [a]
The problem is with ipv6. It gets a ND /64 via DHCP and a PD /48. I want the clients to use SLAAC, so they each get a
/64 from the /48 via DHCP-PD on the router.
The problem seems to be that it’ll only register the /48 on ether1 and ether1 is bound to the pppoe connection. So the clients never get ipv6, because the clients are connected via ether2.
What I’m expecting to see is the ND /64 on the pppoe connection and the /48 in ether2
What do I need to do?
[a] is this the wrong connection type?
