I’m trying to find what’s wrong with my config on ipv6, but it’s not easy.
I’m using ipv6 ND from french provider Free. I’m doing prefix delegation from my modem (freebox pop) to my router (rb4011).
I have multiple vlan on it seems to work as expected for ipv4 (maybe some optimisation / tuning can be made).
And I’ve configured ipv6 delegation only for vlan10-lan & vlan20-iot.
Bu on ipv6, all clients, whatever their respective vlan (vlan10-lan or vlan20-iot), get 2 ips from the delegation (one from each delegation) which is not what I want.
Ip from my laptop
3: wlp0s20f3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether f6:95:79:87:a3:cd brd ff:ff:ff:ff:ff:ff permaddr 30:89:4a:e0:21:5d
inet 192.168.10.63/24 brd 192.168.10.255 scope global dynamic noprefixroute wlp0s20f3
valid_lft 82336sec preferred_lft 82336sec
inet6 2a01:XXX:XX:b6b1:XXXX:XXXX:XXXX:XXXX/64 scope global dynamic noprefixroute
valid_lft 43157sec preferred_lft 1757sec
inet6 2a01:XXX:XX:b6b2:XXXX:XXXX:XXXX:XXXX/64 scope global dynamic noprefixroute
Current configuration:
# 2025-03-31 13:57:43 by RouterOS 7.18.2
# software id = VL6J-0M77
# model = RB4011iGS+
# serial number = B8F30BFFDC65
add admin-mac=C4:AD:34:73:D7:A1 auto-mac=no comment=bridge-lan frame-types=admit-only-vlan-tagged igmp-snooping=yes name=bridge vlan-filtering=yes
set [ find default-name=ether1 ] comment=Freebox
set [ find default-name=ether2 ] comment=tac
set [ find default-name=ether3 ] comment=Mgmt
set [ find default-name=ether4 ] comment="Local Interface 192.168.4.1/24"
set [ find default-name=ether5 ] comment=Trunk
set [ find default-name=ether6 ] comment="Trunk (qnap) 1/2"
set [ find default-name=ether7 ] comment="Trunk (qnap) 2/2"
set [ find default-name=ether8 ] comment=Lan
set [ find default-name=ether9 ] comment="Trunk (hp2915) 1/2"
set [ find default-name=ether10 ] comment="Trunk (hp2915) 2/2"
/interface wireguard
add listen-port=13231 mtu=1420 name=wg0
/interface vlan
add interface=sfp-sfpplus1 name=vlan-internet vlan-id=666
add interface=bridge name=vlan10-lan vlan-id=10
add interface=bridge name=vlan20-iot vlan-id=20
add interface=bridge name=vlan30-cctv vlan-id=30
add interface=bridge name=vlan40-srv vlan-id=40
add interface=bridge name=vlan50-guest vlan-id=50
add interface=bridge name=vlan99-mgmt vlan-id=99
/interface bonding
add comment=hp2915 mode=802.3ad name=hp2915 slaves=ether9,ether10 transmit-hash-policy=layer-3-and-4
add comment=qnap mode=802.3ad name=qnap slaves=ether6,ether7 transmit-hash-policy=layer-3-and-4
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=VLAN
add name=MGMT
add name=dhcp-mgmt ranges=192.168.99.10-192.168.99.254
add name=dhcp-lan ranges=192.168.10.50-192.168.10.99
add name=dhcp-iot ranges=192.168.20.50-192.168.20.99
add name=dhcp-guest ranges=192.168.50.50-192.168.50.99
add name=dhcp-cctv ranges=192.168.30.50-192.168.30.99
add name=dhcp-srv ranges=192.168.40.50-192.168.40.99
add address-pool=dhcp-lan interface=vlan10-lan lease-script=lease-script lease-time=1d name=dhcp-lan
add address-pool=dhcp-iot interface=vlan20-iot lease-script=lease-script lease-time=1d name=dhcp-iot
add address-pool=dhcp-guest interface=vlan50-guest lease-script=lease-script lease-time=1d name=dhcp-guest
add address-pool=dhcp-mgmt interface=vlan99-mgmt lease-script=lease-script lease-time=1d name=dhcp-mgmt
add address-pool=dhcp-cctv interface=vlan30-cctv lease-script=lease-script lease-time=1d name=dhcp-cctv
add address-pool=dhcp-srv interface=vlan40-srv lease-script=lease-script lease-time=1d name=dhcp-srv
/ipv6 pool
add name=lan-ipv6 prefix=2a01:XXX:XX:b6b1::/64 prefix-length=64
/port
set 0 name=serial0
set 1 name=serial1
/system logging action
add name=logserver remote=192.168.40.50 remote-log-format=syslog remote-port=10514 syslog-facility=local6 syslog-severity=emergency target=remote
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether2 pvid=10
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether3 pvid=99
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged interface=ether5 pvid=100
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether8 pvid=10
add bridge=bridge comment="qnap trunk" frame-types=admit-only-untagged-and-priority-tagged interface=qnap pvid=10
add bridge=bridge comment="hp2915 trunk" frame-types=admit-only-vlan-tagged interface=hp2915 pvid=100
add bridge=bridge comment=sfp frame-types=admit-only-vlan-tagged interface=sfp-sfpplus1 pvid=100
set discover-interface-list=MGMT
/ipv6 settings
set accept-router-advertisements=no
/interface bridge vlan
add bridge=bridge comment=main-vlan tagged=bridge,ether5,hp2915 untagged=ether2,ether8,qnap vlan-ids=10
add bridge=bridge comment=mgmt-vlan tagged=bridge,ether5,qnap,hp2915,sfp-sfpplus1 untagged=ether3 vlan-ids=99
add bridge=bridge comment=guest-vlan tagged=bridge,ether5,hp2915,ether2,qnap vlan-ids=50
add bridge=bridge comment=iot-vlan tagged=bridge,ether5,hp2915,qnap,ether2 vlan-ids=20
add bridge=bridge comment=cctv-vlan tagged=bridge,hp2915 vlan-ids=30
add bridge=bridge comment=srv-vlan tagged=bridge,hp2915 vlan-ids=40
add interface=ether4 list=LAN
add interface=vlan10-lan list=LAN
add interface=vlan10-lan list=VLAN
add interface=vlan20-iot list=VLAN
add interface=vlan50-guest list=VLAN
add interface=vlan99-mgmt list=MGMT
add interface=vlan10-lan list=MGMT
add interface=vlan99-mgmt list=VLAN
add interface=wg0 list=VLAN
add interface=vlan30-cctv list=VLAN
add interface=vlan40-srv list=VLAN
add interface=vlan-internet list=WAN
/interface wireguard peers
add allowed-address=10.10.10.0/30,192.168.88.0/24 interface=wg0 name=tic-et-tac-fw public-key="*******"
add address=192.168.4.1/24 interface=ether4 network=192.168.4.0
add address=192.168.10.254/24 comment=vlan10-lan interface=vlan10-lan network=192.168.10.0
add address=192.168.20.254/24 comment=vlan20-iot interface=vlan20-iot network=192.168.20.0
add address=192.168.50.254/24 comment=vlan50-guest interface=vlan50-guest network=192.168.50.0
add address=192.168.99.254/24 comment=vlan99-mgmt interface=vlan99-mgmt network=192.168.99.0
add address=10.10.10.1/30 interface=wg0 network=10.10.10.0
add address=192.168.30.254/24 comment=vlan30-cctv interface=vlan30-cctv network=192.168.30.0
add address=192.168.40.254/24 comment=vlan40-srv interface=vlan40-srv network=192.168.40.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=10m
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no use-peer-ntp=no
add disabled=yes interface=vlan-internet use-peer-dns=no
add address=10.0.10.0/24 dns-server=10.0.10.254 gateway=10.0.10.254 netmask=24
add address=192.168.10.0/24 dns-server=192.168.10.200,192.168.10.201 domain=mk.lan gateway=192.168.10.254 netmask=24
add address=192.168.20.0/24 dns-server=192.168.10.200,192.168.10.201 domain=iot.mk.lan gateway=192.168.20.254 netmask=24
add address=192.168.30.0/24 dns-server=192.168.10.200,192.168.10.201 domain=cctv.mk.lan gateway=192.168.30.254 netmask=24
add address=192.168.40.0/24 dns-server=192.168.10.200,192.168.10.201 domain=srv.mk.lan gateway=192.168.40.254 netmask=24
add address=192.168.50.0/24 dns-server=8.8.8.8,9.9.9.9 domain=guest.mk.lan gateway=192.168.50.254 netmask=24
add address=192.168.99.0/24 dns-server=192.168.99.254 domain=mgmt.mk.lan gateway=192.168.99.254 netmask=24
set allow-remote-requests=yes cache-size=81920KiB doh-max-concurrent-queries=100 doh-max-server-connections=10 doh-timeout=6s mdns-repeat-ifaces=vlan10-lan,vlan20-iot servers=9.9.9.9,149.112.112.112
/ip dns adlist
add ssl-verify=no url=https://cdn.jsdelivr.net/gh/hagezi/dns-blocklists@latest/hosts/light.txt
/ip dns static
add address=192.168.10.1 comment="redirect for local plex" regexp=*.plex.direct type=A
/ip firewall address-list
add address=192.168.20.74 list=SonosDevices
add address=192.168.20.75 list=SonosDevices
add address=192.168.99.10 comment="Proxmox servers" list=pve
add address=192.168.10.200 list=dns
add address=192.168.10.201 list=dns
add address=192.168.40.50 list=dns
add action=drop chain=input comment="crowdsec input drop rules" in-interface=ether1 src-address-list=crowdsec
add action=drop chain=forward comment="crowdsec forward drop rules" in-interface=ether1 src-address-list=crowdsec
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=accept chain=input comment="allow wireguard" dst-port=13231 protocol=udp
add action=accept chain=input comment="Allow main-vlan/MGMT access to all router services" in-interface-list=MGMT
add action=accept chain=input comment="Allow VLAN DHCP" dst-port=67 in-interface-list=VLAN protocol=udp
add action=accept chain=input comment="Allow VLAN DNS UDP" dst-port=53 in-interface-list=VLAN protocol=udp
add action=accept chain=input comment="Allow VLAN DNS TCP" dst-port=53 in-interface-list=VLAN protocol=tcp
add action=accept chain=input comment="Allow VLAN ICMP Ping" in-interface-list=VLAN protocol=icmp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=input comment="Allow srv01-srv to mikrotik" in-interface=vlan40-srv src-address=192.168.40.50
add action=accept chain=input comment="Allow Radius from wg" dst-port=1812-1813 in-interface=wg0 protocol=udp
add action=drop chain=input comment="Drop all other traffic" log-prefix=FW
add action=drop chain=forward comment="Block Internet access" log=yes out-interface=ether1 src-address-list=no-internet
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="VLAN Internet Access Only" connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=accept chain=forward comment="VLAN Allow LAN to MGMT" connection-state=new in-interface=vlan10-lan out-interface=vlan99-mgmt
add action=accept chain=forward comment="VLAN Allow LAN to IOT" connection-state=new in-interface=vlan10-lan out-interface=vlan20-iot
add action=accept chain=forward comment="VLAN Allow LAN to Guest" connection-state=new in-interface=vlan10-lan out-interface=vlan50-guest
add action=accept chain=forward comment="VLAN Allow LAN to SRV" connection-state=new in-interface=vlan10-lan out-interface=vlan40-srv
add action=accept chain=forward comment="VLAN Allow LAN to CCTV" connection-state=new in-interface=vlan10-lan out-interface=vlan30-cctv
add action=accept chain=forward comment="Allow Syslog to vector (openobserver)" dst-address=192.168.40.50 dst-port=10514 in-interface=vlan99-mgmt out-interface=vlan40-srv protocol=udp
add action=accept chain=forward comment="Allow Proxmox Datacenter Manager to Proxmox servers" dst-address-list=pve in-interface=vlan40-srv out-interface=vlan99-mgmt src-address=192.168.40.51
add action=accept chain=forward comment="Allow Komo.do agent" dst-port=8120 in-interface=vlan40-srv out-interface-list=VLAN protocol=tcp src-address=192.168.40.50
add action=accept chain=forward comment="Allow srv01-cctv to NAS" dst-address=192.168.10.1 dst-port=445 in-interface=vlan30-cctv out-interface=vlan10-lan protocol=tcp src-address=192.168.30.50
add action=accept chain=forward comment="Allow srv01-cctv to HA" dst-address=192.168.10.100 dst-port=1883 in-interface=vlan30-cctv out-interface=vlan10-lan protocol=tcp src-address=192.168.30.50
add action=accept chain=forward comment="Allow Espresence to ha (mqtt)" dst-address=192.168.10.100 dst-port=1883 in-interface=vlan20-iot out-interface=vlan10-lan protocol=tcp src-address=192.168.20.80
add action=accept chain=forward comment="Allow pve to srv01-srv" dst-address=192.168.40.50 dst-port=80,443 in-interface=vlan99-mgmt out-interface=vlan40-srv protocol=tcp src-address-list=pve
add action=accept chain=forward comment="Allow srv01-srv to pve" dst-address-list=pve dst-port=8006 in-interface=vlan40-srv out-interface=vlan99-mgmt protocol=tcp src-address=192.168.40.50
add action=accept chain=forward comment="Allow srv02-srv to nas" dst-address=192.168.10.1 dst-port=445 in-interface=vlan40-srv out-interface=vlan10-lan protocol=tcp src-address=192.168.40.53
add action=accept chain=forward comment="Allow from pve to nas" dst-address=192.168.10.1 dst-port=445 in-interface=vlan40-srv out-interface=vlan10-lan protocol=tcp src-address-list=pve
add action=accept chain=forward comment="Allow from pbs-srv to nas" dst-address=192.168.10.1 dst-port=445 in-interface=vlan40-srv out-interface=vlan10-lan protocol=tcp src-address=192.168.40.52
add action=accept chain=forward comment="Allow pve to pbs" dst-address=192.168.40.52 dst-port=8007 in-interface=vlan99-mgmt out-interface=vlan40-srv protocol=tcp src-address-list=pve
add action=accept chain=forward comment="PBX to HA" dst-address=192.168.10.100 in-interface=vlan40-srv out-interface=vlan10-lan src-address=192.168.40.56
add action=accept chain=forward comment="Allow Ecowitt to HA" dst-address=192.168.10.100 dst-port=80 in-interface=vlan20-iot out-interface=vlan10-lan protocol=tcp src-address=192.168.20.67
add action=accept chain=forward comment="Allow Vlan-iot to HA" dst-address=192.168.10.100 dst-port=80 in-interface=vlan20-iot out-interface=vlan10-lan protocol=tcp
add action=accept chain=forward comment="Allow SRV01-SRV to all vlan" in-interface=vlan40-srv out-interface-list=VLAN src-address=192.168.40.50
add action=accept chain=forward comment="Allow Zabbix to srv01-srv" dst-address=192.168.40.50 dst-port=10051 in-interface-list=VLAN out-interface=vlan99-mgmt protocol=tcp
add action=accept chain=forward comment="Allow Sonos to HA" dst-address=192.168.10.100 dst-port=1400 in-interface=vlan20-iot out-interface=vlan10-lan protocol=tcp src-address-list=SonosDevices
add action=accept chain=forward comment="Allow srv02-srv to plex" dst-address=192.168.10.1 dst-port=32400 in-interface=vlan40-srv out-interface=vlan10-lan protocol=tcp src-address=192.168.40.53
add action=accept chain=forward comment="Allow VLANS to DNS udp" dst-address-list=dns dst-port=53 in-interface-list=VLAN protocol=udp
add action=accept chain=forward comment="Allow VLANS to DNS TCP" dst-address-list=dns dst-port=53 in-interface-list=VLAN protocol=tcp
add action=accept chain=forward comment="Allow Port Forwarding - DSTNAT - enable if need server" connection-nat-state=dstnat connection-state=new in-interface-list=WAN
add action=drop chain=forward comment="Drop all other traffic"
add action=redirect chain=dstnat comment=internetprotection disabled=yes dst-port=53 protocol=udp to-ports=53
add action=redirect chain=dstnat comment=internetprotection disabled=yes dst-port=53 protocol=tcp to-ports=53
add action=masquerade chain=srcnat comment="masquerade Allow V-IOT (needed for HA - xiaomi_miio)" ipsec-policy=out,none out-interface=vlan20-iot
add action=dst-nat chain=dstnat comment="Allow Plex" dst-port=32400 in-interface=ether1 protocol=tcp to-addresses=192.168.10.1 to-ports=32400
add action=dst-nat chain=dstnat comment="Allow Urbackup" dst-port=55415 in-interface=ether1 protocol=tcp to-addresses=192.168.10.1 to-ports=55415
add action=dst-nat chain=dstnat comment="Allow saltmaster" disabled=yes dst-port=4505 in-interface=ether1 protocol=tcp to-addresses=192.168.10.118 to-ports=4505
add action=dst-nat chain=dstnat comment="Allow saltmaster" disabled=yes dst-port=4506 in-interface=ether1 protocol=tcp to-addresses=192.168.10.118 to-ports=4506
/ip ipsec profile
/ip kid-control
add fri=0s-1d mon=0s-1d name=Monitor sat=0s-1d sun=0s-1d thu=0s-1d tue=0s-1d wed=0s-1d
/ipv6 route
add disabled=no distance=1 dst-address=::/0 gateway=fe80::3a07:16ff:fe0b:d9d%ether1 routing-table=main scope=30 target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.0.0/16
set ssh address=192.168.0.0/16
set www-ssl certificate=webfig
set api address=192.168.0.0/16
set winbox address=192.168.0.0/16
set api-ssl disabled=yes
/ip traffic-flow
set enabled=yes interfaces=ether1,bridge
/ip traffic-flow target
add dst-address=162.159.65.1 version=5
add dst-address=192.168.40.50 version=ipfix
/ipv6 address
add address=2a01:XXX:XX:b6b1::254 interface=vlan10-lan
add address=2a01:XXX:XX:b6b2::254 interface=vlan20-iot
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" connection-state=established,related
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/ipv6 nd
set [ find default=yes ] advertise-dns=no hop-limit=64 interface=vlan10-lan managed-address-configuration=yes ra-interval=20s-1m
add advertise-dns=no hop-limit=64 interface=vlan20-iot ra-interval=20s-1m
/ipv6 nd prefix default
set preferred-lifetime=30m valid-lifetime=12h
/routing igmp-proxy interface
add interface=vlan10-lan upstream=yes
/system clock
set time-zone-name=Europe/Paris
/system identity
set name=cas-fw
/system logging
add action=logserver topics=critical
add action=logserver topics=error
add action=logserver topics=info
add action=logserver topics=warning
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes multicast=yes
/system ntp client servers
add address=time.cloudflare.com
/system routerboard settings
set auto-upgrade=yes
/tool graphing interface
add interface=ether1 store-on-disk=no
add interface=vlan10-lan store-on-disk=no
add interface=vlan20-iot store-on-disk=no
add interface=vlan50-guest store-on-disk=no
add interface=vlan99-mgmt store-on-disk=no
/tool graphing resource
add store-on-disk=no
/tool mac-server
set allowed-interface-list=MGMT
/tool mac-server mac-winbox
If someone can take a look and show me my mistakes, I would be grateful
