IPV6 no neighbors
I am trying to install a RB2011 as a leaf router.
I have enabled IPV6
The RB2011 does not see the main router, (all clients on same network DO see router)
When trying to configure:
[admin@MikroTikRB2011] /ipv6 nd>
.. – go up to ipv6
add – Create a new item
comment – Set comment for items
disable – Disable items
edit –
enable – Enable items
export – Print or save an export script that can be used to restore configuration
find – Find items by value
get – Gets value of item’s property
prefix –
print – Print values of item properties
remove – Remove item
set – Change item properties
The set command is invalid in this state. print works
the set command prompts
numbers:
rather than settable parameters. Where is the translation between “numbers” and actual parameters?
Confusing…
Gullik
