IPv6 not active ?
I am running software 6.19. I have enabled the ipv6 package and rebooted the router. It shows that package as active. However, I do not have the IPv6 menu and I don’t seem to be able to find a way to configure anything related to IPv6. My end goal is to use IPv6 addresses from the Comcast DHCP server.
I’m missing something very obvious. Do I not need to tell the router to use an IPv6 DHCP server?
is ipv6 menu missing in CLI or in Winbox or both?
are all the packages on the router from same RouterOS build (check in ‘/system packages’)
The are missing in Winbox but are present in CLI (which I am usually not smart enough to use well). My packages are all version 6.19 and every one is enabled except wireless-fp. I have not removed any from the factory installation.
