Hi all, my father is trying to set up a RBM11G with Huawei 909s-120 running RouterOS 7.4.1 and has been running into a problem with configuring it to use LTE.
The quick setup recognizes that the provider is Vodafone and the signal is showing up as good but there is no IP address assigned to it, I know this needs DHCP client to be set up.
There is an issue with the LTE interface not showing up as ‘running’. I tried to set the APN in the APN profiles but keep getting an error saying ‘IPv6 not supported for this device (6)’.
The IPv6 interface is set as none and is disabled in the IPv6 settings. We are both quite lost on this and I would appreciate any help!
