'IPv6 not supported for this device' when 'disable-ipv6: yes'
I use RouterOS 7.1.1 CHR currently, and a lte on passthrough mode;
/ipv6/settings/set disable-ipv6=yes
/system/reboot
when rebooted
/interface/lte/disable lte1
Then print ‘failure: IPv6 not supported for this device
Is that correct?
Actually, yes, because the “disable-ipv6=yes”. This configuration disables IPv6 per device so “IPv6 not supported for this device”.
