Hi there
I have been running Dual stack for a while and I wanted to cut ipv4 part of the internet and try it on ipv6 only
my ISP uses PPPoE so I am getting /56 prefix which I distribute to my local network
to set this up as dual stack I had to
/ipv6 dhcp-client add add-default-route=yes interface=pppoe-isp pool-name=isp-pd use-peer-dns=yes pool-prefix-length=64 request=prefix #Request IPV6 prefix and assign it into its pool
/ipv6 firewall filter add action=accept chain=input comment=”DHCPv6 from provider” dst-port=546 in-interface=pppoe-isp protocol=udp #Added a firewall rule that I do not know its meaning :)
/ipv6 address add address=::1/64 from-pool=isp-pd interface=lan advertise=yes #Added my adress pool to my LAN so computers now get its own IP adress from the prefix
and dual stack works now
but if I disable NAT and turn off DHCP server for my ipv6 computers only get IPV6 adress and Windows 7 reports NO internet in ipv4 section which is good, but nothing works, even ping google.com doesn’t which it should since it is hosted on ipv6 adress
so I suspect its DNS problem, but my provider doesn’t have ipv6 DNS servers and I didn’t see any DNS section in ipv6 tab in winbox, so how do I even configure DNS for ipv6 only network on ipv4 you just add DNS Servers in DHCP Server Networks tab
Windows cannot get DNS server address from IPv6 RA so you need to run a DHCPv6 server for that.
You need to set a fixed option 23 with the IPv6 address(es) you want your clients to use as a 0x11112222333344445555666677778888 hex value corresponding to the DNS server address.
(can be your own router or some external DNS resolver)
The DHCPv6 server on MikroTIk cannot assign IP addresses to the clients.
So you need a hybrid setup where you enable Advertise on the IPv6 address on your LAN (to use RA/SLAAC to assign the address and default route)
and then Linux/Android/Apple devices will get the DNS from that as well (when you Advertise DNS in IPv6->ND), however Windows cannot do that
and it will get the DNS address from DHCPv6.
BTW: How do I specify in RA/SLAAC(Advertise DNS) that I want to use some other DNS Server not mikrotiks?
in ND there is also 6to4 tab not sure but no DNS Server tab where I could specify DNSs IP to advertise
This is indicated by the “managed address configuration” option in the ND settings.
That indicates to the RA listeners that they should use DHCPv6 instead of SLAAC.
However, that is not a usual configuration for IPv6 and you may encounter devices that do not support it.
Newer versions of Windows 10 can get DNS from RA (it came out about a year ago, I guess)
RA in RouterOS takes DNS addresses only from IP->DNS and currently you can’t do anything about it
DHCPv6 does the same, but you can override it with manually created option
You need ‘other configuration’ option enabled in IP->ND, to tell clients to ask DHCPv6
You must not enable ‘managed address configuration’, because that tells clients to use DHCPv6 to get addresses and RouterOS doesn’t support that
Older Windows have hardcoded DNS resolvers (fec0:0:0:ffff::1, fec0:0:0:ffff::2, fec0:0:0:ffff::3), so you can put any of these addresses on router and clients will use them to reach local resolver
