At some point in the last few weeks ipv6 quit working properly. I have an RB5009UG+S+IN running 7.2.3, though I tried downgrading to 7.1.3 since the last time I’m sure it was working was before upgrading. I’m back on 7.2.3 now. I have Comcast residential cable Internet service (in Chicago) and a pretty simple setup. It’s basically reset config, quickset as a router, turn ether8 into a management port, then configure ipv6. I plan to add VLANs & multiple subnets, but figure they’ll just get in the way while debugging this. On the ipv6 side, the DHCP client successfully gets an address and a prefix, machines on the LAN side get their addresses through SLAAC, etc.
I can’t access anything on the WAN side using ipv6 unless I ping the target IP address from the RB5009. If I have a ping going from the RB5009 I can ping from hosts on the WAN and even score 18 out of 20 on ipv6-test.com. ipv6 keeps working for whatever I was pining for a short time after stopping the ping, maybe 20s or so.
When the ping isn’t running on the router I get Address Unreachable errors from the router. I checked with the packet sniffer and nothing goes out on the WAN side. The only icmpv6 traffic is link local stuff, mostly multicast. I’ve also noticed that I never see any “reachable” routers in the neighbor list. I could swear there use to be one back when ipv6 was working.
Anyone have a guess as to what could cause this?
# may/11/2022 21:47:56 by RouterOS 7.2.3
# software id = ZQ4G-PCTF
# model = RB5009UG+S+
# serial number = ************
add admin-mac=XX:XX:XX:XX:XX:9A auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=computers ranges=192.168.101.10-192.168.101.254
add address-pool=computers interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=sfp-sfpplus1
/ipv6 settings
set accept-redirects=no accept-router-advertisements=yes
add interface=ether8 list=LAN
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.101.1/24 comment=defconf interface=bridge network=\
192.168.101.0
add address=192.168.88.1/24 interface=ether8 network=192.168.88.0
/ip dhcp-client
add address=192.168.101.0/24 comment=defconf dns-server=192.168.101.1 \
gateway=192.168.101.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.101.1 comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ipv6 route
add disabled=no dst-address=::/0 gateway=ether1
/ipv6 address
add address=::xxxx:xxxx:xxxx:9a eui-64=yes from-pool=ipv6pool interface=\
bridge
/ipv6 dhcp-client
add interface=ether1 pool-name=ipv6pool prefix-hint=::/61 request=\
address,prefix
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
udp
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/ipv6 nd
set [ find default=yes ] ra-interval=5s-30s
/system clock
set time-zone-name=America/Chicago
/tool mac-server
/tool mac-server mac-winbox
