IPv6 PPPoE Server Help
I am trying to configure my 2011L Routerboard as an IPv6 PPPoE server. I was able to configure IPv4 with no issue. I can also configure IPv6 addresses on the Routerboard and then ping from my Switch–>2011L using IPv6.
It seems like there is nowhere to add “Local” or “Remote” addresses as IPv6 addresses. I configured a pool and am able to authenticate, but when I check active connections it says that my ip is 0.0.0.0. And when I use wireshark, I can see that configure request is requesting 0.0.0.0.
Is it possible to configure the 2011L Routerboard as a PPPoE server?
Thanks a lot for any help! :smiley:
