I have enabled IPV6 on my router running 7.17. It seems to work and passes all the tests on test-ipv6.com.
However, I have some ongoing issues when IPV6 is enabled:
- Chromecast with Google TV and my Sony TV with Google TV, both repeatedly renew their ipv4 lease every few minutes. This causes the connection to reset, interrupting whatever is being viewed. (Interestingly, the issue does not happed with my amazon firestick running the same apps.) These problems go away if ipv6 is turned off.
- Certain apps on our Android phones are either very sluggish or do not work at all. In particular a weather app takes forever to get the current weather (might be a DNS issue?) and Libby (library app) will not download the book content. If ipv6 is disabled in the router both of these apps work fine.
- Sometimes there are long delays, as if DNS is timing out.
My configuration is listed below. Most of it is the default setting in the router. My ISP is Charter/Spectrum. I have tried with “use-peer-dns” yes or no and the problems seems to remain.
Any advice would be appreciated!
/ipv6 dhcp-server option
add code=23 comment="Primary and secondary IPV6 cloudflare family name servers\
. Used by windows." name=DNS value=\
"'2606:4700:4700::1113''2606:4700:4700::1003'"
/ipv6 address
add from-pool=WANv6 interface=bridge-local
add from-pool=WANv6 interface=vlan--guest
/ipv6 dhcp-client
add add-default-route=yes disabled=no interface=ether1-gateway pool-name=\
WANv6 pool-prefix-length=62 prefix-hint=::/56 request=address,prefix \
use-peer-dns=no
/ipv6 dhcp-server
add dhcp-option=DNS interface=bridge-local lease-time=1d name=server1 \
prefix-pool=WANv6
/ipv6 firewall address-list
/ipv6 firewall filter
established,related,untracked
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
"TEMP testing allow winbox from anywhere" disabled=yes dst-port=8291 \
protocol=tcp
add action=drop chain=input comment="drop everything else coming from WAN" \
in-interface-list=WAN
connection-state=invalid
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
add action=drop chain=forward comment="drop everything else coming from WAN" \
/ipv6 nd
set [ find default=yes ] dns=2606:4700:4700::1113,2606:4700:4700::1003
/ipv6 settings
set disable-ipv6=no max-neighbor-entries=8192
