Hi, dear community!
I’m using RB5009 with ROS 7.16.1.
Recently I’ve changed my ISP and it appears that my new ISP supports IPv6. Using IPv6 DHCP client I’ve got the following (addresses are masked, XXXX and YYYY everywhere in the post below are the same):
Received IPv6 address was automatically assigned to interface ether1. From the router I can successfully ping Google’s DNS adddress:
2001:4860:4860::8888
2. IPv6 pool was successfully created with prefix
and after adding the address was automatically changed to the first address from pool: XXXX:YYYY:84f0:2c00::/64
However, no one of my internal devices behind the router didn’t receive any IPv6 address from the pool, only channel local addresses like fe80: are assigned.
I’ve already allowed in IPv6 firewall any UDP in chain input from internal network. By the messages on this forum it looks like IPv6 DHCP server on my router is capable to transfer IPv6 prefixes only (to another routers) and is not used to deliver addresses to clients. From my PC I can successfully ping router’s link-local address of bridge.
What should I do make my MT propagate IPv6 addresses to clients?
The only rule I’ve added was
add action=accept chain=input in-interface-list=LAN protocol=udp
to accept UDP coming from LAN.
UPD: since IPv6 setup router was rebooted twice.
Since the default behavior of the firewall filter in Mikrotik is accept, your rule will not change the overall behavior of the filter, as the “drop everything else” rule in chain input matches on in-interface=!LAN, so it ignores packets arriving via LAN, which then get accepted by default.
But the above has nothing to do with your basic issue, so like in many other “mysterious” cases, I’d suggest sniffing as a way to find out whether the Mikrotik or the LAN host are the reason why SLAAC fails.
So disconnect the Ethernet cable from one of the LAN hosts, run /tool sniffer quick interface=bridge ip-protocol=icmpv6, connect the Ethernet cable back, and stop the sniffer 30 seconds later. Immediately after run /tool sniffer save file=slaac.pcap (the buffer gets purged within minutes), and then download the file and open it using Wireshark. If everything worked, you should see something similar like e.g. here: https://www.cloudshark.org/captures/042b071a3af5 . As it doesn’t work, something will be missing in your case.
As IPv6 requires multicast any badly behaved or configured switches inbetween can prevent IPv6 from working, faulty implementations of DHCP or IGMP snooping are often the cause. So if you have switches between your router and end device(s) check if connecting a device directly to the router works as expected.
sindy, thank you for pointing me on the useless rule. Deleted it.
On the MT dump I can see ONLY packets coming to router from my PC (connected by ethernet). No any packet sent from the router. Thank you for the site, posted my dump here: https://www.cloudshark.org/captures/5d2b2e829c20
It seems like MT is not responding…
Hi, tdw! I have no any devices between MT and clients.
Please post the complete export of your configuration (minus all the passwords and usernames, public addresses etc.). If you have indeed sniffed on the bridge, not on the ethernet interface, it looks really weird, as if you had some bridge filter rule there or an IPsec policy.
sindy, attached my exported and slightly cleaned configuration. This router is also a CAPsMAN, zerotier ang wireguard client. Also I’ve never used IPsec. And I have no any bridge filter rules. conf_export_masked.rsc (9.64 KB)
Your export says /ipv6 address
add from-pool=IPv6-pool interface=bridge
This means that you have set address=::, so the resulting address is a “subnet router anycast address”, which I believe cannot be assigned as an individual unicast address of an interface. So try changing that to the ::1 you’ve shown in the OP and try again.
If this is not the issue, the only thing to come to my mind except a mere bug is that attaching the DHCPv6 server to the bridge might prevent the router from responding to the Router Solicitation requests.
I’ve finally found a solution, but it more about “magic”, not to a real solution: in Winbox I’ve opened /IPv6/ND, checked “Advertise DNS” flag, applied change, then unchecked that flag back and applied changes again. After that MT started reply with Router Advertisement (RA) to the clients. It looks like ND settings were specified but not actually applied and not worked until first apply. It looks like bug workaround, not a real solution…
