Hi, i purchased a RB450G a couple of days ago with the intent to use it as a robust NAT router with a 6in4 tunnel from sixxs with accompanying subnet.
As far as getting the tunnel working on the router it’s working just fine and i can do /ping
just fine.
But on the LAN side with the bridge having IPv6 IP prefix of 2001:16d8:cc0b::/64 defined it will send the RA. And the clients gets IPv6 IPs… BUT, they won’t get a default route to ::/0 via the router at all…
Any help and pointers why this is the case?. it should get a default route afaik. since radvd on a linux server that preceeded it provided it with both ip and route just fine. but the routerboard just won’t give a route :S.
EDIT(00:08 11-11-2011), Tried after googling around disabling the master-port settings and only used 1 port for my LAN instead of having kit connected to the RB450G ports and then default route works fine…, so for anyone using IPv6 ND/RA on RB450G or any other routerboard device.. don’t use switching or bridging is a lesson to be learnt. shame it doesn’t work, but i’ll survive without those extra 3 ports.
