RouterOS: 6.24
Hardware: CRS125-24G-1S
Firmware: 3.19
I have a problem with IPv6 RAs leaking out of VLANs.
Consider the following configuration:
/interface bridge add disabled=no name=bridge9
/interface vlan add disabled=no interface=ether17 name=vlan9 vlan-id=9
add bridge=bridge9 interface=ether9
add bridge=bridge9 interface=vlan9
/ipv6 address
add address=2a03:c222:8:101:1:: advertise=yes interface=ether17
add address=2a03:c222:8:109:1:: advertise=yes interface=bridge9
A Windows PC plugged into ether17 (and without any VLANs configured) receives the following addresses:
Windows IP Configuration
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
IPv6 Address. . . . . . . . . . . : 2a03:c222:8:101:5d4f:a465:7962:e18f
IPv6 Address. . . . . . . . . . . : 2a03:c222:8:109:5d4f:a465:7962:e18f
Temporary IPv6 Address. . . . . . : 2a03:c222:8:101:7db1:b7b9:f29d:b288
Temporary IPv6 Address. . . . . . : 2a03:c222:8:109:7db1:b7b9:f29d:b288
Link-local IPv6 Address . . . . . : fe80::5d4f:a465:7962:e18f%3
IPv4 Address. . . . . . . . . . . : XXXXXXXXXXXXXXXXXXXXXXXXXX
Subnet Mask . . . . . . . . . . . : XXXXXXXXXXXXXXXXXXXXXXXXXX
Default Gateway . . . . . . . . . : fe80::d6ca:6dff:fe08:ff67%3
So, not only is it receiving RAs which were meant to be on the VLAN only, it isn’t setting up a default IPv6 gatway. Essentially, to me, this means that IPv6 is unusable.
Now, it is always possible I have made a mistake - if somebody can see something in the above configuration which I have done wrong, I will be more than grateful. I have, of course, sent an e-mail to support@…
