ROS v7.4. what’s the problem with ipv6 routing table?
if I add an ipv6 address on bridge2 , some addresses will be unroutable , even if I didn’t change anything on /ipv6 route.
[admin@MT] > ipv6 route pri
Flags: D - DYNAMIC; A - ACTIVE; c, d, v, y - COPY
Columns: DST-ADDRESS, GATEWAY, DISTANCE
DST-ADDRESS GATEWAY DISTANCE
DAv ::/0 pppoe 1
DAd 240e:3a0:5ac6:fcf0::/60 1
DAc 240e:3a0:5ac6:fcf0::/64 bridge 0
DAc fe80::%ether1/64 ether1 0
DAc fe80::%bridge/64 bridge 0
DAc fe80::%pppoe/64 pppoe 0
DAc fe80::%bridge2/64 bridge2 0
[admin@MT] > too trace 2600::1 //real internet addr
Columns: ADDRESS, LOSS, SENT, LAST, AVG, BEST, WORST, STD-DEV
# ADDRESS LOSS SENT LAST AVG BEST WORST STD-DEV
1 240e:320:1060::54 0% 2 2.7ms 2.7 2.6 2.7 0.1
2 240e:320:60:1f6:: 0% 2 2.9ms 3 2.9 3 0.1
3 240e:320:0:12c:: 0% 2 8.3ms 8.3 8.2 8.3 0.1
4 240e:380:1:2:401:471:: 0% 2 8.1ms 8.5 8.1 8.8 0.4
5 240e:380:1:2:203:401:1:0 0% 2 13.5ms 13.5 13.5 13.5 0
6 240e:380:0:1:203:2c6:0:1 0% 2 14.9ms 14.8 14.7 14.9 0.1
7 240e:380:0:4:2c6:2f6:2:0 0% 2 16.3ms 16.2 16 16.3 0.2
8 240e:380:0:4:2f6:294:1:0 0% 2 18.1ms 17.8 17.4 18.1 0.4
9 2402:4f00:100::88d 0% 2 45.6ms 45.6 45.6 45.6 0
10 2402:4f00:100::24a 0% 1 78.6ms 78.6 78.6 78.6 0
11 2001:de8:4::1239:1 0% 1 234ms 234 234 234 0
12 2600:0:2:1239:203:222:33:154 0% 1 230.1ms 230.1 230.1 230.1 0
13 2600::1 0% 1 227.6ms 227.6 227.6 227.6 0
[admin@MT] > too trace 27ff:: //unreal internet addr,just test where it goes
1 240e:320:1060::54 0% 2 2.4ms 2.4 2.4 2.4 0
2 240e:320:60:179:: 0% 2 2.8ms 2.9 2.8 2.9 0.1
3 240e:320:0:92a:: 0% 2 5.8ms 5.9 5.8 5.9 0.1
4 240e:380:1:2:401:472:: 0% 2 7.7ms 7.7 7.6 7.7 0.1
5 240e:380:1:2:203:401:: 0% 2 16.5ms 16.5 16.5 16.5 0
6 100% 2 timeout
7 100% 1 timeout
8 100% 1 timeout
9 100% 1 timeout
10 100% 1 timeout
[admin@MT] > too trace 2800:: //unreal internet addr,just test where it goes
1 240e:320:1060::54 0% 2 2.3ms 2.3 2.2 2.3 0.1
2 240e:320:60:972:: 0% 2 3ms 3.2 3 3.4 0.2
3 240e:320:0:1960:: 0% 2 5.9ms 7.5 5.9 9 1.6
4 240e:380:1:2:402:474:: 0% 2 9.5ms 9.5 9.5 9.5 0
5 240e:380:1:2:204:402:1:0 0% 2 21.9ms 18.4 14.8 21.9 3.6
6 100% 2 timeout
7 100% 2 timeout
8 100% 1 timeout
9 100% 1 timeout
10 100% 1 timeout
[admin@MT] > too trace 2a01:4f8:c0c:bd0a::1 //real internet addr
1 240e:320:1060::54 0% 3 2.1ms 2.2 2.1 2.3 0.1
2 240e:320:60:179:: 0% 3 3.1ms 2.9 2.7 3.1 0.2
3 240e:320:0:12c:: 0% 3 7.9ms 8 7.9 8 0
4 240e:380:1:2:401:471:: 0% 3 7.9ms 8 7.9 8.1 0.1
5 240e:380:1:2:203:401:: 0% 3 16.5ms 16.6 16.5 16.6 0
6 240e:380:0:1:203:2c6:0:1 0% 3 14.7ms 14.6 14.5 14.7 0.1
7 240e:380:0:4:2c6:2f6:2:0 0% 3 15.7ms 15.8 15.7 16 0.1
8 240e:380:0:4:2f5:294:1:0 0% 3 17.1ms 16.8 16.4 17.1 0.3
9 2402:4f00:2000:100::6a5 0% 3 255.8ms 254.9 254.4 255.8 0.7
10 2402:4f00:2000:100::71d 0% 3 262.9ms 250.1 243.5 262.9 9.1
11 2001:7f8::616c:0:1 0% 3 244.2ms 244.2 244 244.3 0.1
12 2a01:4f8:0:3::356 0% 3 252.4ms 248.4 246 252.4 2.8
13 2a01:4f8:0:e0c0::a25e 0% 3 246.9ms 246.8 246.6 246.9 0.2
14 2a01:4f8:0:e0c0::a27e 0% 2 248ms 255.8 248 263.5 7.8
15 100% 2 timeout
16 2a01:4f8:0:e0c0::3119 0% 2 246.8ms 247.1 246.8 247.4 0.3
17 2a01:4f8:c0c:bd0a::1 0% 2 248.4ms 248.1 247.8 248.4 0.3
↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑BEFORE↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑↑
[admin@MT] > /ipv6 address add address=2a03:a004:f090::2 advertise=no interface=bridge2
↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓AFTER↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓↓
DAv ::/0 pppoe 1
DAc 2a03:a004:f090::/64 bridge2 0
[admin@MT] > too trace 2600::1 //normal as before
1 240e:320:1060::54 0% 3 2.2ms 2.3 2.2 2.5 0.1
2 240e:320:60:1f6:: 0% 3 3.5ms 3.2 3 3.5 0.2
3 240e:320:0:12c:: 0% 3 8.4ms 8.2 8.1 8.4 0.1
4 240e:380:1:2:401:471:: 0% 3 8.2ms 9.3 8.2 10.9 1.2
5 240e:380:1:2:203:401:1:0 0% 3 13.5ms 13.6 13.5 13.7 0.1
6 240e:380:0:1:203:2c6:0:1 0% 3 14.9ms 14.8 14.7 14.9 0.1
7 240e:380:0:4:2c6:2f6:2:0 0% 3 15.9ms 15.9 15.7 16 0.1
8 240e:380:0:4:2f6:294:1:0 0% 3 17.4ms 18.7 17.4 21.3 1.8
9 2402:4f00:100::88d 0% 3 45.7ms 45.9 45.7 46.1 0.2
10 2402:4f00:100::24a 0% 3 76.9ms 77.6 76.9 78.1 0.5
11 2001:de8:4::1239:1 0% 3 234.4ms 234.6 234.2 235.2 0.4
12 2600:0:2:1239:203:222:33:154 50% 3 timeout 230 230 230 0
13 2600::1 0% 2 228.1ms 228.4 228.1 228.6 0.3
[admin@MT] > too trace 27ff:: //normal as before
1 240e:320:1060::54 0% 2 2.5ms 2.4 2.3 2.5 0.1
2 240e:320:60:179:: 0% 2 2.9ms 2.8 2.7 2.9 0.1
3 240e:320:0:92a:: 0% 2 5.9ms 5.8 5.7 5.9 0.1
4 240e:380:1:2:401:472:: 0% 2 7.6ms 7.9 7.6 8.1 0.3
5 240e:380:1:2:203:401:: 0% 2 16.5ms 16.6 16.5 16.6 0.1
6 100% 2 timeout
7 100% 1 timeout
8 100% 1 timeout
9 100% 1 timeout
10 100% 1 timeout
[admin@MT] > too trace 2800:: //seems that it doesn't know where to go ,for destination from 2800::/5
Columns: LOSS, SENT, LAST
# LOSS SENT LAST
1 100% 3 timeout
2 100% 3 timeout
3 100% 3 timeout
4 100% 2 timeout
5 100% 2 timeout
# LOSS SENT LAST
1 100% 2 timeout
2 100% 2 timeout
3 100% 2 timeout
4 100% 1 timeout
5 100% 1 timeout
