IPv6 Route 'USHI' flags on RouterOS v7.11.2 CCR2116
Good afternoon,
I am encountering an abnormal issue on a CCR2116 running RouterOS V7.11.2 in relation to base IPv6 configuration. My current goal is simple; to add a peering IPv6 address and route. Confirm ping to/from gateway on IPv6.
Upon configuring the IPv6 route with a Ping gateway check it is observed immediately entering an ‘Unreachable’, ‘Hardware Offloaded’ and ‘Inactive’ state. I cannot ping to or from the site via IPv6.
If IPv6 Hw is disabled under Switch>L3 HW-Settings why am I seeing the ‘Hardware Offloaded’ flag?
Many hours of head/desk bashing later and I’m not any closer to getting this route up.
I have enabled and configured IPv6 for a good 50+ sites previously on older generations of RouterOS and never experienced an issue similar to this.
Any ideas? Did something change in the newer revisions of RouterOSv7 that I am missing? I don’t have this issue on a nearby site utilizing a CCR2004 on RouterOSv7.6.
H-flag does not indicate that route is actually HW offloaded, it indicates only that route can be selected to be HW offloaded.
https://help.mikrotik.com/docs/display/ROS/L3+Hardware+Offloading#L3HardwareOffloading-SuppressingHWOffload
Thank you for the clarification chechito!
This case is solved. The root cause for the issues experienced was due to an invalid IPv6 subnet.
