fqx
February 28, 2022, 9:19am
1
I get my IPv6 addresses from ISP by prefix, then I config local LAN with SLAAC.
With Add Default Route enabled, I will get two routes auto configured.
1st
2nd
I have to delete first route manually to get IPv6 work.
What could cause this? How can I fix it?
RB5009UG+S+
7.1.3
Znevna
February 28, 2022, 9:31am
2
You uncheck add default route.
fqx
February 28, 2022, 11:22am
3
If I uncheck add default route, it seems that the second route won’t add automatically either.
pe1chl
February 28, 2022, 12:16pm
4
You should have “add default route” in the PPPoE client interface and NOT in the DHCPv6 client.
Then it will work OK, maybe after a disable/enable of the PPPoE.
fqx
March 8, 2022, 12:59am
5
I tried your suggestion.
The result is that the first route will be added automatically, the second route is gone.
pe1chl
March 8, 2022, 9:22am
6
And then it works. Case closed.
