I have an RB5009UPr+S+ which I'm using to provide 4 apartments Internet access via a cable provider. This provider gives a /60 via PD and the router is receiving that, and I have it setting the interface addresses for the VRFs. IPv4 is working, well other than fasttrack causing the VRF's to slow to a crawl (60kbit/s), but I was able to exempt them from processing and they appear to be going at line rate now.
IPv6 should be rather simple, add ::/0 to each VRF via the %bridge-local@main and then a route from main to the VRF for the pool IP. This may need to be done via bgp, but at this point I'm just statically defining it to test. I'm unable to ping between the VRFs in testing and via a second test host as well. I can ping the VRF interfaces in the VRF, and even get SLAAC on the test APT1 client, it just doesn't make it out. I've mostly disabled the firewall for v6 and can't seem to get anywhere.
I'm no expert in mikrotik, so am I missing something? Is this something due to using bridge local and VLANs in different VRFs?
VRFs
VRF-APT1
VRF-APT2
VRF-APT3
VRF-APT4
Interfaces
WAN: ether8
LAN: bridge-local
APT1 - VLAN 101 on bridge-local
APT2 - VLAN 102 on bridge-local
APT3 - VLAN 103 on bridge-local
APT4 - VLAN 104 on bridge-local
routing table
[admin@SPBGFLRT01] /ipv6/route> print
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT, s - STATIC, d - DHCP, g - SLAAC
Columns: DST-ADDRESS, GATEWAY, ROUTING-TABLE, DISTANCE
# DST-ADDRESS GATEWAY ROUTING-TABLE DISTANCE
D d ::/0 fe80::7201:b5ff:fecd:9019%ether8 main 1
DAg ::/0 fe80::7201:b5ff:fecd:9019%ether8 main 0
;;; ONE-Default
0 s ::/0 bridge-local main 1
DAc ::1/128 lo main 0
DAd 2603:9000:9608:1ff0::/60 main 1
DAc 2603:9000:9608:1ff0::/64 bridge-local main 0
1 s 2603:9000:9608:1ff0::/64 bridge-local main 1
2 As 2603:9000:9608:1ff1::/64 APT1@VRF-APT1 main 1
DAc 2603:9000:ff00:96:4019:aeaa:12e4:17df/128 ether8 main 0
DAc fe80::/64 ether8 main 0
DAc fe80::/64 bridge-local main 0
3 As ::/0 bridge-local VRF-APT1 1
DAc 2603:9000:9608:1ff1::/64 APT1@VRF-APT1 VRF-APT1 0
DAc fe80::/64 APT1@VRF-APT1 VRF-APT1 0
DAc 2603:9000:9608:1ff2::/64 APT2@VRF-APT2 VRF-APT2 0
DAc fe80::/64 APT2@VRF-APT2 VRF-APT2 0
DAc 2603:9000:9608:1ff3::/64 APT3@VRF-APT3 VRF-APT3 0
DAc fe80::/64 APT3@VRF-APT3 VRF-APT3 0
DAc 2603:9000:9608:1ff4::/64 APT4@VRF-APT4 VRF-APT4 0
DAc fe80::/64 APT4@VRF-APT4 VRF-APT4 0
Routes and trying to ping between them
[admin@SPBGFLRT01] /ipv6/route> export
# 2026-06-06 13:47:14 by RouterOS 7.23.1
# software id = 77VT-KL7R
# model = RB5009UPr+S+
# serial number = HFG094Z4V9A
/ipv6 route
add comment=ONE-Default disabled=no distance=1 dst-address=::/0 gateway=bridge-local pref-src="" routing-table=main vrf-interface=bridge-local
add disabled=no distance=1 dst-address=2603:9000:9608:1ff1::/64 gateway=APT1@VRF-APT1 pref-src="" routing-table=main
add disabled=no distance=1 dst-address=2603:9000:9608:1ff0::/64 gateway=bridge-local pref-src="" routing-table=VRF-APT1 vrf-interface=\
bridge-local
add disabled=no dst-address=::/0 gateway=bridge-local@main routing-table=VRF-APT1
[admin@SPBGFLRT01] /ipv6/route> /ping 2603:9000:9608:1ff0::1 vrf=VRF-APT1
SEQ HOST SIZE TTL TIME STATUS
0 2603:9000:9608:1ff0::1 timeout
1 2603:9000:9608:1ff0::1 timeout
2 2603:9000:9608:1ff0::1 timeout
sent=3 received=0 packet-loss=100%
[admin@SPBGFLRT01] /ipv6/route> /ping 2603:9000:9608:1ff1::1
0 2603:9000:9608:1ff1::1 timeout
1 2603:9000:9608:1ff1::1 timeout
2 2603:9000:9608:1ff1::1 timeout
[admin@SPBGFLRT01] /ipv6/route> /ping 2603:9000:9608:1ff1:: vrf=
VRF-APT1 VRF-APT2 VRF-APT3 VRF-APT4 main
[admin@SPBGFLRT01] /ipv6/route> /ping 2603:9000:9608:1ff1:: vrf=VRF-APT1
arp-ping as-value count do-not-fragment dscp interval proplist size src-address ttl without-paging
0 2603:9000:9608:1ff1::1 56 64 348us echo reply
0 2603:9000:9608:1ff1::1 56 64 484us echo reply
1 2603:9000:9608:1ff1::1 56 64 371us echo reply
1 2603:9000:9608:1ff1::1 56 64 515us echo reply
2 2603:9000:9608:1ff1::1 56 64 345us echo reply
2 2603:9000:9608:1ff1::1 56 64 489us echo reply
sent=3 received=6 packet-loss=-100% min-rtt=345us avg-rtt=425us max-rtt=515us
[admin@SPBGFLRT01] /ipv6/route> /ping 2603:9000:9608:1ff1::1 vrf=VRF-APT1
0 2603:9000:9608:1ff1::1 56 64 353us echo reply
0 2603:9000:9608:1ff1::1 56 64 488us echo reply
1 2603:9000:9608:1ff1::1 56 64 347us echo reply
1 2603:9000:9608:1ff1::1 56 64 491us echo reply
sent=2 received=4 packet-loss=-100% min-rtt=347us avg-rtt=419us max-rtt=491us
0 2603:9000:9608:1ff0::1 56 64 368us echo reply
1 2603:9000:9608:1ff0::1 56 64 352us echo reply
2 2603:9000:9608:1ff0::1 56 64 342us echo reply
sent=3 received=3 packet-loss=0% min-rtt=342us avg-rtt=354us max-rtt=368us
config
# 2026-06-06 13:51:54 by RouterOS 7.23.1
add admin-mac=78:9A:18:D6:14:7C auto-mac=no comment=defconf name=bridge-local port-cost-mode=short
set [ find default-name=ether4 ] l2mtu=1514 name=WAP-AP1
set [ find default-name=ether5 ] l2mtu=1514 name=WAP-AP2
set [ find default-name=ether1 ] l2mtu=1514 name=WAP-APT3 rx-flow-control=auto tx-flow-control=auto
set [ find default-name=ether2 ] l2mtu=1514
set [ find default-name=ether3 ] l2mtu=1514
set [ find default-name=ether6 ] l2mtu=1514
set [ find default-name=ether7 ] l2mtu=1514
set [ find default-name=ether8 ] l2mtu=1514
set [ find default-name=sfp-sfpplus1 ] l2mtu=9008 mtu=1520
/interface vlan
add interface=bridge-local name=APT1 vlan-id=101
add interface=bridge-local name=APT2 vlan-id=102
add interface=bridge-local name=APT3 vlan-id=103
add interface=bridge-local name=APT4 vlan-id=104
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp0 ranges=192.168.0.100-192.168.0.249
add comment=APT-ONE-POOL name=ONE-POOL ranges=172.19.1.101-172.19.1.199
add address-pool=dhcp0 authoritative=after-2sec-delay interface=bridge-local lease-time=10m name=dhcp1
add address-pool=ONE-POOL interface=APT1 name=ONE
/ip smb users
/ip vrf
add interfaces=APT4 name=VRF-APT4
add interfaces=APT3 name=VRF-APT3
add interfaces=APT2 name=VRF-APT2
add interfaces=APT1 name=VRF-APT1
/routing id
add disabled=no id=192.168.3.211 name=id-1 select-dynamic-id="" select-from-vrf=main
/routing ospf instance
add disabled=no name=ospf-instance-1 originate-default=never redistribute=connected,static,ospf router-id=192.168.3.211 routing-table=main
/routing ospf area
add disabled=no instance=ospf-instance-1 name=ospf-area-0
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 disabled=yes
add addresses=0.0.0.0/0 authentication-protocol=SHA1 encryption-protocol=AES name=KeeklesSNMP security=private
add bridge=bridge-local comment=defconf interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge-local comment=defconf interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge-local comment=defconf interface=WAP-AP1 internal-path-cost=10 path-cost=10
add bridge=bridge-local comment=defconf interface=WAP-AP2 internal-path-cost=10 path-cost=10
add bridge=bridge-local comment=defconf interface=ether6 internal-path-cost=10 path-cost=10
add bridge=bridge-local comment=defconf interface=ether7 internal-path-cost=10 path-cost=10
add bridge=bridge-local comment=defconf interface=WAP-APT3 internal-path-cost=10 path-cost=10
add bridge=bridge-local comment=defconf interface=sfp-sfpplus1 internal-path-cost=10 path-cost=10
set udp-timeout=10s
set discover-interface-list=all lldp-mac-phy-config=yes lldp-max-frame-size=yes lldp-med-net-policy-vlan=1 lldp-vlan-info=yes
/ipv6 settings
set accept-router-advertisements=yes
/interface bridge vlan
add bridge=bridge-local tagged=WAP-AP2,WAP-AP1,WAP-APT3 vlan-ids=1,100-105
add comment=defconf interface=bridge-local list=LAN
add comment=defconf interface=ether8 list=WAN
add interface=APT1 list=LAN
add interface=APT2 list=LAN
add interface=APT3 list=LAN
add interface=APT4 list=LAN
add address=192.168.3.211 interface=lo network=192.168.3.210
add address=192.168.0.254/24 interface=bridge-local network=192.168.0.0
add address=172.19.1.254/24 comment="APT1 LAN" interface=APT1 network=172.19.1.0
add address=172.19.2.254/24 comment="APT2 LAN" interface=APT2 network=172.19.2.0
add address=172.19.3.254/24 comment="APT3 LAN" interface=APT3 network=172.19.3.0
add address=172.19.4.254/24 comment="APT4 LAN" interface=APT4 network=172.19.4.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf default-route-tables=main,VRF-APT1,VRF-APT2,VRF-APT3,VRF-APT4 interface=ether8 name=ether8
/ip dhcp-server lease
add address=172.19.1.0/24 comment=APT-ONE-LAN dns-server=1.1.1.1 gateway=172.19.1.254 netmask=24
add address=192.168.0.0/24 comment="Apt3 Lan" dns-server=192.168.8.150,1.1.1.1 gateway=192.168.0.254
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set servers=192.168.8.150
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=192.168.0.0/24 comment=local list=allowed_to_router
add address=192.168.0.0 comment=mgmt list=MGMT
add address=192.168.0.0/16 comment=mgmt list=MGMT
add action=accept chain=input comment="allow mgmt" in-interface-list=WAN src-address-list=MGMT
add action=accept chain=forward comment="51413 in" dst-port=51413 in-interface-list=WAN protocol=tcp
add action=accept chain=forward comment="42615 tcp in" dst-port=42615 in-interface-list=WAN protocol=tcp
add action=accept chain=forward comment="42615 udp in" dst-port=42615 in-interface-list=WAN protocol=udp
add action=accept chain=forward comment="51413 in" dst-port=51413 in-interface-list=WAN protocol=udp
add action=accept chain=input comment="allow all from tunnel interface" in-interface=TAMSFLDERT1
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked disabled=yes
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid log=yes
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=forward comment="defconf: accept in ipsec policy" ipsec-policy=in,ipsec log=yes
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related disabled=yes
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid log=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new \
add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=!LAN log=yes
/ip firewall mangle
add action=mark-connection chain=prerouting connection-state=new new-connection-mark=APT1 passthrough=no src-address=172.19.1.0/24
add action=mark-connection chain=prerouting connection-state=new new-connection-mark=APT2 passthrough=no src-address=172.19.2.0/24
add action=mark-connection chain=prerouting connection-state=new new-connection-mark=APT3 passthrough=no src-address=172.19.3.0/24
add action=mark-connection chain=prerouting connection-state=new new-connection-mark=APT4 passthrough=no src-address=172.19.4.0/24
add action=mark-routing chain=prerouting connection-mark=APT1 in-interface-list=WAN new-routing-mark=VRF-APT1
add action=mark-routing chain=prerouting connection-mark=APT2 in-interface-list=WAN new-routing-mark=VRF-APT2
add action=mark-routing chain=prerouting connection-mark=APT3 in-interface-list=WAN new-routing-mark=VRF-APT3
add action=mark-routing chain=prerouting connection-mark=APT4 in-interface-list=WAN new-routing-mark=VRF-APT4
add action=dst-nat chain=dstnat comment="torrent to lunchladydoris" dst-port=51413 in-interface-list=WAN protocol=udp to-addresses=192.168.0.245 \
to-ports=51413
add action=dst-nat chain=dstnat comment="torrent to lunchladydoris" dst-port=51413 in-interface-list=WAN protocol=tcp to-addresses=192.168.0.245 \
to-ports=51413
add action=dst-nat chain=dstnat dst-port=42615 in-interface-list=WAN protocol=tcp to-addresses=192.168.0.60 to-ports=42615
add action=dst-nat chain=dstnat dst-port=42615 in-interface-list=WAN protocol=udp to-addresses=192.168.0.60 to-ports=42615
/ip nat-pmp
set enabled=yes
/ip nat-pmp interfaces
add interface=bridge-local type=internal
add interface=WAP-APT3 type=external
add disabled=yes distance=1 dst-address=192.168.0.0/16 gateway=192.168.255.17 routing-table=main scope=30 target-scope=10
/ipv6 route
bridge-local
/ip service
set www-ssl disabled=no
/ipv6 address
add from-pool=delegation interface=bridge-local
add address=0:0:0:1::1 from-pool=delegation interface=APT1
add address=0:0:0:2::1 from-pool=delegation interface=APT2
add address=0:0:0:3::1 from-pool=delegation interface=APT3
add address=0:0:0:4::1 from-pool=delegation interface=APT4
/ipv6 dhcp-client
add add-default-route=yes allow-reconfigure=yes interface=ether8 pool-name=delegation pool-prefix-length=64 prefix-hint=::/60 request=\
address,prefix use-interface-duid=yes
/ipv6 firewall address-list
/ipv6 firewall filter
add action=fasttrack-connection chain=forward comment="Enable FastTracked v6 traffic" connection-state=established,related
add action=accept chain=forward comment="accept established,related,untracked" connection-state=established,related,untracked disabled=yes
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=accept chain=input comment="defconf: accept ICMPv6" disabled=yes protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" disabled=yes port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." disabled=yes dst-port=546 protocol=udp src-address=\
fe80::/10
add action=accept chain=input comment="defconf: accept IKE" disabled=yes dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" disabled=yes protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" disabled=yes protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" disabled=yes ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked disabled=\
yes
add action=accept chain=input comment="Accept DHCPv6 client prefix delegation" disabled=yes dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=forward comment="defconf: accept ipsec AH" disabled=yes protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept IKE" disabled=yes dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" disabled=yes ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept ICMPv6" disabled=yes protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ipsec ESP" disabled=yes protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept HIP" disabled=yes protocol=139
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" disabled=yes in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" disabled=yes src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" disabled=yes hop-limit=equal:1 protocol=icmpv6
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" disabled=yes in-interface-list=!LAN
/ipv6 nd
set [ find default=yes ] advertise-dns=yes hop-limit=64 interface=bridge-local
add hop-limit=64 interface=ether8
add advertise-dns=yes dns=2606:4700:4700::1111,2606:4700:4700::1001 hop-limit=64 interface=APT1
/routing filter rule
add chain=ospf-in disabled=no rule="if (dst == 192.168.0.0/16 ) { accept } else {reject}"
add chain=ospf-out disabled=no rule="if (dst == 192.168.0.0/16 ) { accept } else {reject}"
/routing ospf interface-template
add area=ospf-area-0 disabled=no prefix-list=192.168.0.0/16
/routing settings
set policy-rules=vrf-lookup,vrf-unreach,mangle,local,user,main
/system clock
set time-zone-name=America/New_York
/system identity
set name=SPBGFLRT01
/tool mac-server
/tool mac-server mac-winbox
Diagram
I've been suggested that I need to mark the packets in the IPv6 firewall, but this should be simple routing, no NAT, just forwarding traffic, so I don't think that's needed.
From my testing, is IPv6 in VRF's just not supported?
