Hi!
I'm quite new to RouterOS, just having configured a CRS-125 and a CCR-1009 over the weekend. So far, everything is up and running and performing great!
However, I have been struggling to get IPv6 support working for my setup. My ISP, Fiber7/Init7 supports native IPv6 with SLAAC-PD, giving each customer a /48
I'm still quite new to RouterOS, as well as IPv6, so bear with me if I get something incorrect or omit some information.
Following configuration recommendations from RouterOS - RouterOS - MikroTik Documentation I have the following configured so far:
/ipv6 address
add from-pool=Fiber7 interface=bridge1
/ipv6 dhcp-client
add add-default-route=yes interface=combo1 pool-name=Fiber7 request=prefix
My addresses and routes look like so:
ipv6 address print
Flags: X - disabled, I - invalid, D - dynamic, G - global, L - link-local
ADDRESS FROM-POOL INTERFACE ADVERTISE
0 G 2a02:168:64f2::1/64 Fiber7 bridge1 yes
1 DL fe80::66d1:54ff:fed4:dd2f/64 bridge1 no
2 DL fe80::66d1:54ff:fed4:dd2e/64 combo1 no
ipv6 route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, o - ospf, b - bgp, U - unreachable
DST-ADDRESS GATEWAY DISTANCE
0 ADS ::/0 fe80::ca9c:1dff:fe05:... 1
1 ADSU 2a02:168:64f2::/48 1
2 ADC 2a02:168:64f2::/64 bridge1 0
With this setup, I am able to successfully ping external IPv6 addresses from the router, via the WAN interface. However, nothing inside my LAN is able to reach out via IPv6, and I am unable to ping external IPv6 addresses via the LAN interface on the router:
/ping 2001:1620:2777:1::10%combo1
SEQ HOST SIZE TTL TIME STATUS
0 2001:1620:2777:1::10 56 59 1ms echo reply
1 2001:1620:2777:1::10 56 59 0ms echo reply
/ping 2001:1620:2777:1::10%bridge1
0 2001:1620:2777:1::10 timeout
Ping results from a host inside the LAN:
ping6 2001:1620:2777:1::10
PING 2001:1620:2777:1::10(2001:1620:2777:1::10) 56 data bytes
From 2a02:168:64f2:0:201:2eff:fe6c:b9ee icmp_seq=32 Time exceeded: Hop limit
From 2a02:168:64f2:0:201:2eff:fe6c:b9ee icmp_seq=33 Time exceeded: Hop limit
Any ideas what I am missing here? With previous router hardware/software I had IPv6 working without issue, so I am assuming I am missing something in the configuration of RouterOS, but I am stumped as to what I am missing. Let me know if any additional information would help here.
Thanks!
