IPV6 settings in Router os 7.19 via PPPoE over SLAAC dual stack
Router gets a ipv6 address but other devices don’t get ipv6 address.
2404::8/64 (removed partially) connection type Dynamic.
TP Link router gets ipv6 for all connected devices
Please provide your current router configuration in text format. There are no telepaths on this forum. :wink:
PFB Router configuration
2025-07-02 12:11:22 by RouterOS 7.19.2
model = E50UG
add admin-mac=F4:1E:00:00:00:00 auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 user=\
    0000000000000
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/queue interface
set ether5 queue=multi-queue-ethernet-default
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
/ipv6 settings
set forward=no
    192.168.88.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
    192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ipv6 address
add from-pool=airpool interface=bridge
/ipv6 dhcp-client
add add-default-route=yes default-route-tables=main interface=pppoe-out1 \
    pool-name=airpool prefix-hint=::/64 request=prefix
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/ipv6 nd
set [ find default=yes ] hop-limit=64 interface=bridge other-configuration=\
    yes
/tool mac-server
/tool mac-server mac-winbox
  • First, you should turn back on IPv6 Forward under IPv6 → Settings.
/ipv6 settings set forward=yes
  • Then because you use PPPoE for your WAN, which is point-to-point, you should not set add-default-route=yes in your DHCPv6 Client setting. Turn that off because the default gateway is already the other peer of the PPPoE tunnel.
  • Other Configuration can also be turned off for the IPv6 → ND instance.
/ipv6 nd set [ find default=yes ] other-configuration=no
I would also remove the prefix hint form dhcp v6 client. And double check if the dynamic pool is created with something bigger than /64 (usually /56).
And, for ND, as this is PPPoE, I would announce 1492 as network MTU.
Regards.
  1. First, check that you are receiving any pool from your provider via DHCPv6 Client.
  2. Considering that you are only requesting a pool from your provider, I would set the EUI64 parameter in the “/ipv6 address” settings.
Thanks for revert, your instruction worked.
