IPv6 token support?
does RouterOS include IPv6 token [1][2] support? I've searched the docs and played around with various config options, but it doesn't seem to be supported. IPv6 tokens are quite useful for ULAs as well as non-static GUAs/prefixes (e.g. in many domestic scenarios).
If it's not supported, I hope it's something that Mikrotik could consider adding support for. Given that support is already provided by the Linux kernel, I guess it wouldn't be too complicated to do.
[1] https://datatracker.ietf.org/doc/id/draft-chown-6man-tokenised-ipv6-identifiers-02.txt
[2] https://man7.org/linux/man-pages/man8/ip-token.8.html
I believe you’re correct that it’s not currently supported.
There’s many, many ways to approach IPv6, this would be a very handy option to have available IMO.
