Hello!
I’m trying to setup IPv6 in my VPS with CHR (v 7.15). VPS provider gave me a /64 prefix and fe80::1 as gateway. Here’s config on my side (first 4 blocks of addresses are omitted):
/ipv6 address
add address=0000:0000:0000:0000:: advertise=no interface=ether1
add address=0000:0000:0000:0000:abc:: advertise=no interface=ether1
add address=0000:0000:0000:0000:cba:: advertise=no interface=ether1
add address=0000:0000:0000:0000:cba:123:: advertise=no interface=ether1
add address=0000:0000:0000:0000:cba:abc:: advertise=no interface=ether1
/ipv6 firewall filter
add action=accept chain=input connection-state=established,related
add action=accept chain=input protocol=icmpv6
add action=accept chain=input dst-port=46380 protocol=udp
add action=accept chain=input in-interface=WG-v6 protocol=ospf
add action=accept chain=input dst-port=8291 protocol=tcp
add action=drop chain=input
add action=accept chain=forward in-interface=WG-v6 out-interface=ether1
add action=drop chain=forward
/ipv6 nd
set [ find default=yes ] advertise-dns=no disabled=yes interface=ether1 ra-interval=20s-1m
/ipv6 route
add disabled=no dst-address=::/0 gateway=fe80::1%ether1 routing-table=main suppress-hw-offload=no
The problem is that when I ping 0000:0000:0000:0000:: it seems to instead respond with the lexicographically last address (so now it’s :cba:abc:: - if I disable it, then :cba:123:: and so on). Is this a bug, or maybe the “subnet IP” is not intended to be white? They keep rebooting me to Linux and telling that everything is working on it, so I should check my configuration.
