Hey Guys,
Posting this from a router that’s running a free ipv6 tunnel from tunnelbroker.net (he.net) which works great.
This uses a 6in4 tunnel to their servers to pass back either a /64 or if requested a /48 block that you can break up yourself.
I was however wondering if there was any support for TSP (http://en.wikipedia.org/wiki/Tunnel_Setup_Protocol) enabled connections or if there will be any in the future?
Currently the distance from me to the nearest he.net server is such that I have a 300ms hop in my ipv6 connections.
There are 2 major providers of IPv6 tunnels here in Australia however both only use TSP as the connection configuration option.
More info on IPv6 tunnel brokers can be found here along with the connection methods used: http://en.wikipedia.org/wiki/List_of_IPv6_tunnel_brokers
Edit: if anyone can alternatively suggest how I’d go about getting the correct details etc from a TSP client (such as the hexago client) this would also be great.. if I figure it out myself I’ll post back here ![]()
