IPv6 Tunnel Site to Site
for a multi-site IPv6 project I need to establish a tunnel between two sites.
SiteA: 2001:4dd0:ff01::/48
SiteB: 2A01:1:2::/48
SiteC: 2001:4dd0:ff02::/48
On Site B there is a Teredo-Gateway (MS DirectAccess) which also does some IPsec-Tunneling. How to tell the nodes on site A and C, that they should use a host in site B as their Teredo-Gateway? By just placing a route like 2001:0::/32 2A01:1:2::/48 for example doesn’t work, as this host isn’t a direct neighbor.
I think I need a connection between both sites without using IPv4 - as this traffic is counted by the provider - IPv6 isn’t. Is their something implemented in ROS, i can use? A PPTP or something like this would be nice, but it must use IPv6 for transport.
Thanks for your ideas
Stefan
Hey, no ideas or is my question to stupid?
if you have IPv6 between sites, you should not have any problems communicating using IPv6. If there are only IPv6, you can make the usual tunnel and run IPv6 over tunnel, so both sites will have IPv6 enabled.
Hi Janisk,
when I place a route 2001::/32 pointing to one of the other, more than one hops away routers, the package doesn’t arrive nor the route isn’t shown as active route.
I will investigate this issue again in a few minutes and come back.
Please stand by.
Stefan
So, here is my Routing-Table:
/ipv6 route print
C - connect, S - static, r - rip, o - ospf, b - bgp, U - unreachable
DST-ADDRESS GATEWAY DISTANCE
0 A S 2000::/3 2001:4dd0:ff00:f5::1 1
1 S 2001::50be:9793:0:0:0... 2a01:138:9003:18::189 1
2 ADC 2001:4dd0:ff00:f5::/64 SixXS 0
3 ADC 2001:4dd0:ff70:1::/64 bridge01_LAN-WLAN 0
And this is the traceroute:
/tool traceroute 2a01:138:9003:18::189
ADDRESS STATUS
1 2001:4dd0:ff00:f5::1 50ms 51ms 50ms
2 2001:4dd0:1234:3:dc40::a 50ms 50ms 51ms
3 2001:4dd0:a2b:21:dc30::1 50ms 50ms 50ms
4 2001:4dd0:a2b:14:10::b 54ms 53ms 53ms
5 2001:7f8::3cee:0:2 54ms 53ms 54ms
6 2a01:138::113:0:0:0:9 62ms 62ms 62ms
7 2a01:138::1d1:0:0:4:1 62ms 62ms 63ms
8 2a01:138:9003::20 62ms 61ms 62ms
9 2a01:138:9003:10::2 62ms 62ms 61ms
10 2a01:138:9003:18::189 61ms 62ms 61ms
As you can see, the route is inactive - and I think this is by design of IPv6. Thats why I need to have a tunnel, to get the routers as direct neighbors. Or you tell me, how to reach my wish. :slight_smile:
Best regards
Stefan
Hey? Any solution? Is there someone, who could confirm that I’m on the right or wrong way?
