I currently have a proxmox server running two services
- mikrotick chr
- pfsense
CHR is used to manage a cat 16 lte modem to passthrough (bridge) the LTE connection to pfsense. pfsense is then used as the firewall.
Using EE, I’m forced to use cgnat for my connection. To try to circumvent this I’m investigating cloudflare tunnel and ipv6 passthrough.
Ideally I’d like to use ipv6 passthrough but I can’t seem to get it to work on mikrotik CHR. I keep getting the following error.
Please ignore that the IP-type is set as IPv4 in the screenshot. I initially had IP-Type set as auto, tried IPv6 passthrough to ether1 (LTEWAN for pfsense) but it didn’t work. So i decided to leave the IP-Type as IPv4 only
