Rules are evaluated in strict order, if you drop any packets arriving from an interface in the WAN list destined for an interface in the LAN list before other rules then bidirectional communication will always fail.
With the not working example replies to connections initiated from LAN devices will also be dropped by the first rule in addition to attempted connections initiated from WAN devices.
With the working example replies to connections initiated from LAN devices are permitted as the initial outbound packet from the LAN device creates a connection table entry so the reply matches established. Only then will packets which have not been matched by the first rule be processed by the second rule.
