IPX Using Routerboard 230
Dear List;
Hope someone has had some experience with this !
I am currently setting-up a wireless Network for a client using IPX Ver4.
Due to the sensitive nature of IPX a few special requirements are needed to have a network using this protocol, function well…
I have a Routerboard 230 which I’m using to connect three IPX (Novell) Servers. The IP Side of this are working well (servers Ping’ing) and all routes have been setup successfully.. have RTFM and could only find reference to Bridges - and have configured as suggested by the RouterOS Ref manual.. with no luck… I just cant get the IPX side of things up and running..
Any help will greatly be appreciated.
:confused:
In RouterOS IPX traffic could be only bridged, not routed. Assuming you have set up bridging correctly everything should work.
If you still have problems, post your config.
